Tiling Interior Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 07-12-2012, 01:07 PM   #1
tiling interior stairs
I currently have carpet on my stairs leading to the bonus room (about 7 stairs). The flooring downstairs is tile so I'd like to tile the stairs. I'm trying to figure out the best way to do this. Also, I have extra tile from my floors and thought I would break them and create a mosaic look on the tread part of the stairs, then leave the clean-cut tile on the riser. Any opinions on this?
dwhite426 is offline   Reply With Quote
Old 07-12-2012, 01:22 PM   #2
Rewards Points: 14,312
Yes, do not tile them.
Use laminited real wood treads instead.
Old 07-12-2012, 01:56 PM   #3
I think tiled stairs (porcelain ) are a big fall hazard. A textured or unfired tile less so.
Evstarr is offline   Reply With Quote
Old 07-12-2012, 09:21 PM   #4
Rewards Points: 960
I've done two staircases, both with a rough porcelain.
The stringers were attached to studded walls on both sides. The stairs were 3' wide. There were 2x8 risers and 2x10 treads which I attached with adhesive & screws, then densshield mortared on top of that and screwed or nailed on.
I had densshield going down the stringer as well and I used 12x12 tiles. I used a lot of caulk on the changes in plane and was only able grout the middle joints.
Very solid and no complaints or regrets.
cleveman is offline   Reply With Quote
Old 07-13-2012, 08:17 AM   #5
Thanks for your comment. My only concern is that I have tile throughout my downstairs (no wood flooring anywhere). I think the wood stairs would look out of place. What if I used slate or a textured tile (nothing slick)?
Old 07-13-2012, 08:22 AM   #6
Thanks for your comment. My stairs are between walls except for the bottom 3 stairs. What kind of nose did you put on the edge of each stair?
Old 07-13-2012, 08:30 AM   #7
Rewards Points: 960
I just used the factory edge. It was through and through porcelain, so it looked fine.
If this doesn't work for you, you could try a schlueter profile. I think "Treppe" would be the way to go.
I forgot to mention, I stair-stepped the tile down the stringer, as opposed to cutting a line.
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 07:03 PM
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
First tiling project, need some help DIYD Tiling, ceramics, marble 1 08-06-2009 06:15 AM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
