Old 03-02-2008, 10:04 PM   #1
tiling guestion
I have researched tiling over tile and feel comfortable with the process. I will be re-modeling a bath and will remove the existing bathtub and vanity. The vanity will actually be smaller and the tub will be replaced with a claw foot version. When I remove them I'm assuming that they will not have tile underneath. I'm thinking that the best way to do that is to use cement board with a sheet of plywood of whatever thickness to build to the correct level.
IS this the right technique or should I do something else?
Scottp is offline   Reply With Quote
Old 03-03-2008, 10:00 AM   #2
Tile Contractor
Bill_Vincent's Avatar
tiling guestion
It all depends on what you find when you remove the tub and vanity. Hopefully, that's all you'll need. One way or the other, when you install the cement board, make sure you thinset it down as well as using either screws of nails.
"Whether you think you can, or you think you can't, You're probably right."
Bill_Vincent is offline   Reply With Quote
Tiling over a bathtub lip The Kid Remodeling 19 02-04-2012 12:46 PM
Tiling - what a nightmare Richo Flooring 9 01-06-2008 09:02 PM
Tiling inside a fireplace Patricia Building & Construction 4 09-02-2006 08:51 PM
How scuffed should old tile be before tiling over w/ new J187 Flooring 3 07-25-2006 09:01 PM
bathroom tiling neptunian General Discussion 1 03-29-2005 08:44 AM
