-   -   Tiling a foyer (http://www.diychatroom.com/f5/tiling-foyer-128972/)
bemgolf 01-05-2012 10:46 PM
[B][/B] Tiling a foyer
I am starting my first tile job and am needing some help. I have heard its all in the planning and that is the stage I am in. I was wanting to know about proper thin set. Under the carpet is osb in great shape so no concerns there. I wanted to see besides thin set under backer board is a Redgard or Ditra for a foyer really needed. Also since this is on osb and there will be movement I should probably us Modified thin set. Is this correct? Any other great beginners advice you can give would be greatly appreciated.
ps
The foyer is 12 x 5 rectangular
joecaption 01-05-2012 11:19 PM
No Red Guard is needed. It's only used in wet areas.
The rest sounds fine, personaly I would go over the area with a layer of 3/8 under layment rated plywood screwed down to the floor every 4" on the edges and evey 6 to 8" in the field.
Bud Cline 01-05-2012 11:28 PM
Could you further explain that comment? Why will there be movement?
bemgolf 01-06-2012 01:12 AM
I meant not on concrete.
Bud Cline 01-06-2012 01:22 AM
Shouldn't be any undo movement.
You can use either cement board (1/4"-1/2") in thinset or DITRA (1/8"-5/16") in thinset.
Which underlayment you choose could determine which thinset to use.
