-   -   Tiling floor around bathtub (http://www.diychatroom.com/f5/tiling-floor-around-bathtub-17271/)
digexpressions 02-18-2008 02:45 PM
I will be re tiling the floor in my bathroom. I had a question regarding how to tile around the bathtub area. Is it best to tile right up to the side of the tub or should there be a grout line there? Does it make a functional difference or is it just aesthetic? I saw a contractor caulking around a tub on a laminate flooring, is this also done on tile? Not sure how this would look. Any advice would be greatly appreciated. Thanks.
jerryh3 02-18-2008 02:59 PM
Leave approx 1/8" between the edge of the tile and the tub and fill with a quality silicone caulk. Do not fill with grout because it will likely crack.
JazMan 02-18-2008 04:08 PM
I agree the gap should be caulked. I do not recommend silicone though. Most people would make a royal mess of it, plus you're limited to the colors you can get.
I recommend leaving an 1/8" (+-) gap and using a caulk color to match the floor grout. Matching caulk is available from all grout manufacturers, including both unsanded and sanded varieties.
Jaz
Bud Cline 02-18-2008 05:02 PM
Caulking laminate to a tub? How does that work I wonder? Floating laminate flooring caulked to anything wouldn't last more than forty seconds I wouldn't think.:)
Leave 1/8" gap and caulk it with grout-matching caulk.....oh wait, Jaz already said that. :)
mike costello 02-18-2008 05:26 PM
Floating laminate in a bathroom period is a bad deal
JazMan 02-18-2008 08:12 PM
Floating laminate floor ANYWHERE is a bad idea! It's cheap looking, sounding, feeling etc. It's possibly a half step up from vinyl is all. I mean it's fine, but some toot it as an upgrade premium floor, it is not. :whistling2:
Jaz
