Tiling A Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-23-2010, 09:04 PM   #1
Tiling a floor
I'm installing backer board in a bthroom and i've already cut the pieces to fit where they need to go. Do you install the closet flange on top of the backer board or under it?
cdl1223 is offline   Reply With Quote
Old 11-23-2010, 09:22 PM   #2
Rewards Points: 292
I think ideally, you want to end up with the flange flush to your finished tile floor.
Jim F is offline   Reply With Quote
Old 11-23-2010, 09:23 PM   #3
bottom of flange should be flush with the finished floor
warnerww is offline   Reply With Quote
Old 11-23-2010, 09:32 PM   #4
Just to be sure, if the flange is on top of the cement backer board and I tile up to the flange, should I worry about water leaking from the toilet?
Old 11-23-2010, 09:36 PM   #5
I like to leave the flange loose enough so I can slide the tile under the flange. It should not leak if the toilet is installed correctly. I do not caulk around my toilet for a few weeks just so i can check and make sure it is not leaking.
The Following User Says Thank You to warnerww For This Useful Post:
cdl1223 (11-23-2010)
Old 11-23-2010, 10:17 PM   #6
I'm also putting a Pedestal sink in, should I install the pedastal ontop of the Backer board or tile first and place the Pedastal on the tiles?
Old 11-23-2010, 10:31 PM   #7
Tile first then put sink in
Old 11-23-2010, 11:01 PM   #8
thanks again.
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Tiling on cement floor hollya Flooring 1 02-02-2010 02:07 PM
Movement in bathroom floor rob_di_mostly_y Kitchen & Bath Remodeling 2 07-24-2009 03:37 PM
tiling kitchen...how to treat electrical outlet on floor? tarheelblue Flooring 3 01-28-2008 03:31 PM
