Tiling A Fireplace. - Flooring - DIY Chatroom Home Improvement Forum
Old 01-20-2010, 03:41 PM   #1
Tiling a fireplace.
We have a painted brick fireplace that I would like to tile over. Do I need to prepare the surface because it is painted? We use the fireplace with an insert and burn wood. Is there specific tile to be used and mortar/thinset in order to withstand the heat? Thanks!
carinmc is offline   Reply With Quote
Old 01-20-2010, 05:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If you are tiling the face surface of the surround heat shouldn't be an issue if you use thinset mortar. In truth the paint should be scuffed back to the brick. Typically a painted surface can be a bond-breaker for a tile installation but in the case of a brick structure there should be plenty of edges for the thinset to grab onto.
XXX
Old 01-22-2010, 10:45 AM   #3
Hi
I did the exact procedure as commented by Bud, a few years ago and have had "0" problems with my tile work. It's all about the surface prep.
Good Luck!
SilverBullit is offline   Reply With Quote
Tiling Fireplace Bper Building & Construction 1 12-06-2008 12:02 PM
Fireplace surround tiling Ducowti General DIY Discussions 8 10-28-2008 09:16 AM
tiling a fireplace Jack Hass Remodeling 2 07-28-2008 09:04 AM
Tiling inside a fireplace Patricia Building & Construction 4 09-02-2006 07:51 PM
