Tiling Error Around Tub. Any Suggestions? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-06-2012, 11:23 PM   #1
Tiling error around tub. Any suggestions?
Hey all, long time reader, first time poster. I was wondering if their may be a easy solution to my first tiling error around my tub.
I began to tile today around my tub and ended up with a problem. It was due to an installation issue with the durock last week. Anyway my finished tile sits on top of my tub lip. However the front of the tub, my tile has a 1/2 inch gap between itself and the tub lip at its worst spot. (I tried to post a pic but it won't allow iPhone pics to be uploaded) I know it should have gone over the lip preventing water to fall in the tub when it hits the tile, however was wondering if anyone had any solutions? I was thinking :
1. Use silicone caulking to seal the gap
2. I have some glass mosaic tile I could try to make some border with to cover the gap
3. Can the ceramic tile vinyl edgers be used?
Any help appreciated.
Tile newbie is offline   Reply With Quote
Old 04-06-2012, 11:50 PM   #2
Rewards Points: 13,450
Silicone will never work for that big a gap, a sure way to end up with subfloor and wall damage.
Trying to use a narrow row of tiles will at the bottom of the wall will fail, the tub moves a small amount and will cause the tiles to flex and crack or crack the grout.
If you talking about those cheap stick on vinyl mouldings, there just not going to stay stuck, been there done that.
Why was the wall not started at the bottom row?
Old 04-07-2012, 02:11 AM   #3
Location: Crusader House 2nd Floor 145 157 St Johns Street London UK
Smile
You can re-tile over the existing tile, or remove them and then tile over that concrete or mortar bed layer. I prefer to remove them, you'll often get a better feel for what you are dealing with and it'll last longer.
fangeos2 is offline   Reply With Quote
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
Suggestions for my Kitchen ktm General DIY Discussions 7 04-08-2011 08:13 AM
unstable subfloor for tiling hohadcr Flooring 2 08-27-2010 12:10 AM
Building a new deck......suggestions? thoughts? Rhizzlebop Building & Construction 38 06-24-2009 05:07 PM
is this bad tiling or am I being fusy??? rodger_j Flooring 23 07-16-2008 03:44 PM
