Tiling To Edge Of Basement Stairs....what Is Tha Rubber Strip I Need? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-09-2012, 07:41 AM   #1
Sephora's Avatar
Rewards Points: 150
Tiling to edge of basement stairs....what is that rubber strip I need?
When we tiled the kitchen floor last Oct we went close to the edge of the basement 1st step. There is this long rubber piece I need to put where the tile didn't meet the edge. I looked at the box stores and couldn't find anything. Do I get it at a tile store?
What is it called?
Sephora is offline   Reply With Quote
Old 08-09-2012, 08:25 AM   #2
DIY staff
Rewards Points: 7,174
I don't know exactly what you are referring to---
Floor to stair nosings are often wood --set flush to the tile surface--
Or aluminum -L shaped overlayed nosing
Or an aluminum profile (look at Schluter) that is set into the thinset as the tiles are installed.
A picture of your stair /tile termination would help you get good suggestions on how to finish that---Mike----
Old 08-09-2012, 08:39 AM   #3
Rewards Points: 13,712
Or even just butted up to the threshold leaving a gap that gets filled with caulking.
Are you talking about a vinyl baseboard?
Old 08-09-2012, 08:43 AM   #4
DIY staff
Joe--he's talking about the edge of the basement stairs-----no thresh hold there---Mike---
Old 08-09-2012, 09:08 AM   #5
Sephora's Avatar
Rewards Points: 150
What SHE (as in me) (LOL...yes females are on here) meant was something like this. But it seems I should have installed prior to tiling.
Wonder if they have them without the metal that is supposed to go under tile at edge.
Old 08-09-2012, 09:33 AM   #6
And what would keep then from twisting off if there not under the tile and attached to the tread?
Old 08-09-2012, 09:51 AM   #7
DIY staff
How much room do you have,if any, between the end of the tile and edge of the step?
The Hows and Whys of Furring Strips. Part-1 Willie T How To Guides 12 03-01-2013 02:58 PM
tiling interior stairs dwhite426 Flooring 6 07-13-2012 08:30 AM
Drywall above stairs into basement mcjeffren Building & Construction 3 05-26-2011 07:55 AM
Basement egress stairs June Benninger Building & Construction 0 08-07-2010 01:54 AM
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 03:49 PM
