Tiling In Cold Weather - Flooring - DIY Chatroom Home Improvement Forum
Old 11-20-2009, 01:46 PM   #1
Tiling in cold weather
I have a sunroom 100sq' in area that isn't heated. Temps here in Virginia can get down to 32F. The question is, should I wait until spring to tile or what are the tricks for tiling in cold weather....type grout, thin set, durock or hardibacker what about the effects of cold and hot weather on the flexing? The present floor is tongue and groove wood underfloor is plywood.
pglc is offline   Reply With Quote
Old 11-20-2009, 03:23 PM   #2
Remodeling Contractor
thinset is a type of cement. Cement is comfortable when you are. (50 F to 70 F) So I would recommend you wait. You can add anti-hydro and cover with insulated blankets if you have to. this will allow you to work down to temps of 20F.
Old 11-20-2009, 04:22 PM   #3
Thanks Bob, I'll take your advice and wait until spring. Let me ask this, doing the work in the spring next winter will the tiles contract and possibly crack?
Old 11-20-2009, 05:13 PM   #4
Not if installed correctly and an expansion joint is left around the perimeter of the room.
R&D Tile is offline   Reply With Quote
Sealing new blower for cold weather (foto) diy-diy HVAC 0 10-26-2009 10:50 PM
Cedar Decking and Cold Weather project_guy Building & Construction 3 01-29-2009 05:32 AM
Cold Weather Interior Painting psustang89 Painting 7 05-18-2008 11:47 PM
Cold Weather Concrete in Post Hole OK?? Jerrycast Building & Construction 6 01-25-2008 09:47 AM
