Tiling On Cement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 02-02-2010, 01:09 PM   #1
Tiling on cement floor
We are adding a bathroom in our basement. Does the cement floor need to be level in order to lay ceramic tile? If it's not level, will that case problems later on?
hollya is offline   Reply With Quote
Old 02-02-2010, 02:07 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Ceramic tiles don't particularly care if a floor is level or not. They do however care if the floor is flat. Don't confuse level with flat. The bigger the tiles the flatter the floor must be.
Use modified thinset mortar adhesive from a bag that you mix with water. DON'T let anyone convince you to use the premixed adhesives, they won't hold up on a basement concrete floor.
XXX
Non cement based floor leveler /patch troyce1 Flooring 9 07-08-2012 09:35 AM
Levelling floor for tiling wedge22 Flooring 2 06-02-2009 10:05 AM
Refinishing cement garage floor question redpen Flooring 1 05-31-2009 10:07 PM
Floating floor over cement gwendda Flooring 4 07-18-2006 04:58 PM
Uneven\Buldging Cement Basement Floor SSandecki Flooring 5 12-20-2005 05:06 PM
