Tiling The Bathroom - Flooring - DIY Chatroom Home Improvement Forum
Old 01-26-2011, 10:55 AM   #1
Tiling the Bathroom
I bought a home that's fully carpeted. I hate the idea of having carpeting in the bathroom, but I'm not sure what's underneath it.
It looks like the carpet pad is stapled to wooden planks maybe 2" wide. Not sure why the wood is painted white. It doesn't look like plywood, though, and I think (hope) that's a good thing.
Is this the floor, or is there another layer underneath it these white boards are nailed to?
I believe that to properly tile, I'll have to float in concrete to prevent cracking. Assuming there is a plywood subfloor beneath these boards, would the move be to pull them out, float concrete on the plywood, and tile on top of that? The adjacent room is the same story as this one, so that would work out well from a thickness perspective.
Thanks!
mab123 is offline   Reply With Quote
Old 01-26-2011, 10:57 AM   #2
Experienced
Jackofall1's Avatar
Looks like hardwood flooring to me, why its painted white, your guess is as good as mine.
Mark
Old 01-26-2011, 10:58 AM   #3
Is there a standard thickness range for hardwood? The house was built in 1981. Thanks again for your help!
Old 01-26-2011, 11:02 AM   #4
Experienced
Jackofall1's Avatar
You will have to do some investigating on that one, if its old T&G then its undoubtedly 3/4" thick, but what kind of sub-floor is it set on, is a question you will have to find the answer to.
Old 01-26-2011, 11:05 AM   #5
Fair enough. Thanks again.
Old 02-02-2011, 02:31 AM   #6
i would say not to waste time cleaning it up, depending on height dif where the rooms meet, if you can just buy new plywood, screw it down over the whole floor, make sure nothings rotten under b4 u do that, you'll have a fresh clean floor to work with. taking all that paint off is a waist of time
Last edited by cutallnight; 02-02-2011 at 02:33 AM. Reason: forgot to add something
cutallnight is offline   Reply With Quote
Old 02-02-2011, 06:46 AM   #7
DIY staff
Rewards Points: 7,174
Is there an air duct on that floor?
Old 02-02-2011, 07:19 AM   #8
woodman58's Avatar
The paint looks like Kilz to cover up pet stains. If your putting ceramic tile down you can just go over the floor with a concrete backer board or Ditra if you are cocerned about hight.
woodman58 is offline   Reply With Quote
Old 02-02-2011, 07:53 PM   #9
My two cents is tear the corner up and use a hole saw to check the thickness of the subfloor if in doubt. If it is 3/4" you should be fine with tiling over it as long as it is level and study. Some people beef up their subfloor for tile by adding additional plywood before the backerboard. If you have rotten subfloor replace it. I'd suggest just using 5/16" durrock and going over the 3/4". I'm sure someone will chime in about deflection which is fine but the transitions need to make sense and hopefully not exceed 3/4" so you can find a transtion device that makes sense. So tear up the carpet, take up the toilet and vanity (if you are changing the vanity), cut in your board, mortar under the board, screw or nail the board down, lay full tiles, speed set your cuts, and grout. Good luck.
FlooringDude is offline   Reply With Quote
Old 02-02-2011, 07:59 PM   #10
Experienced
Jackofall1's Avatar
I would think, just my humble opinion, that laying tile onto an old hardwood floor, even if sound, would be risky as hardwood floors do move, and move alot from season to season.
Just my 2 cents.
Mark
Old 02-02-2011, 09:43 PM   #11
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That appears to be be strip flooring of some kind and if so it is not suitable to tile over without first adding a layer of plywood, minimum 3/8".
XXX
Tiling a bathroom... with uneven floors dianaslik Flooring 14 01-23-2012 08:37 AM
Prep work for tiling bathroom damian Flooring 2 06-12-2010 07:27 PM
What kind of wall for tiling bathroom and shower ghostdog Remodeling 1 03-26-2009 05:17 AM
Tiling bathroom ivaiva Project Showcase 3 08-30-2008 08:24 AM
Tiling half a bathroom jeannieB Remodeling 9 06-20-2008 11:44 AM
