Tiling In The Basement? - Flooring - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 05:58 PM   #1
Question
Tiling in the basement?
I want to put thinset over painted concrete that has cutback on it. Then i want to tapcon down hardieboard over it and then thinset over that then tile. Is it doable? Any other ideas? Thank you for your time!
kidnitro6 is offline   Reply With Quote
Old 03-31-2012, 05:59 PM   #2
Maybe consider grinding the concrete and the laying tile right to the concrete. You can rent a grinder.
RhodesHardwood is offline   Reply With Quote
The Following User Says Thank You to RhodesHardwood For This Useful Post:
kidnitro6 (04-01-2012)
Old 03-31-2012, 08:04 PM   #3
DIY staff
Rewards Points: 7,174
Tile can be set right over the cutback---use a two part thinset like Kerabond and Keralastic by Mepei-
"Mud" What is it?
Old 04-01-2012, 08:45 AM   #4
It also has epoxy paint over parts of the cutback.... Previous owner did that
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 01:13 AM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
