Tiling Backsplash Over Sheetrock With Glue - Flooring - DIY Chatroom Home Improvement Forum
Old 07-03-2011, 10:13 AM   #1
tiling backsplash over sheetrock with glue
Had a backsplash made of formica..pulled off the formica and there is glue all over the wall. Plan to scrape off excess glue and oil base prime any rips in the sheetrock. Do you think I can tile over this glue? Is there anything else I should do? Thanks
diylady is offline   Reply With Quote
Old 07-03-2011, 10:18 AM   #2
DIY staff
Rewards Points: 7,174
You should be fine---as long as the surface is flat enough.
Old 07-03-2011, 10:58 AM   #3
does it have to be perfectly flat or can it have some imperfections
Old 07-03-2011, 11:05 AM   #4
DIY staff
That depends a lot on the tile you are using---bigger tiles will take a thicker layer of thinset and can tolerate a bit of unevenness-- Small mosaics?---Better be good and flat or the work will show the bad wall.
Skim coating the glue ridges might be an option---I'd have to see how bad the wall is before I could offer an opinion.
Old 07-13-2011, 08:31 PM   #5
Lightfoot's Avatar
Rewards Points: 272
I'm glad you asked this question, because i'm remodeling a rental house and i have the same scenario. I was hoping a search would turn up some answers. The glue on mine is very smooth on a wall of 1/4 inch plywood placed on top of drywall. Would i need to cover the plywood with something else, or prime the surface and proceed?
Lightfoot is offline   Reply With Quote
Old 07-13-2011, 08:32 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Prime it with a liquid waterproofing for tile and go for it.
XXX
Old 07-13-2011, 08:41 PM   #7
DIY staff
A lot of 1/4" plywood is Luan--which is very absorbent and not water proof at all--as a mater of fact it will start to delaminate from the water in the thinset.
So --I second what Bud suggested---buy a tub of Red Guard at the depot--paint on the water proofer--and then set your tiles with a modified thin set.----You will be good to go--Have fun---Mike---
tiling kitchen backsplash shannon2000 Kitchen & Bath Remodeling 1 05-21-2011 07:46 PM
Tiling backsplash smh2b1g General DIY Discussions 1 10-12-2010 02:35 PM
tiling over laminate/formica backsplash doqfleed Tiling, ceramics, marble 4 06-14-2010 11:25 PM
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 01:01 PM
Tiling kitchen backsplash deeaa Building & Construction 6 07-17-2008 08:44 PM
