#1 |
Tiling around a slipper tub - any tricks?
I am renovating a very small bathroom. Right now there's carpeting on the floor, and I want to rip it up and put down some sort of tile. The only thing that's stopping me is that I have no idea how to tile behind the tub, which has a 1 1/2" clearance from the lip of the tub to the back wall, and only limited space on the sides to slip my arm around.
I'm wondering if there's some sort of waterproof something I can pour back there, on the parts I can't reach? I know the perfect answer would be to remove the tub, but I don't think it would be possible for us at this time. Thanks for your brain power
#2 |
Tile Contractor
How about enclosing it, and making a shelf at the end of the tub?
"Whether you think you can, or you think you can't, You're probably right." To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#3 |
That's actually a really good idea.
I'd like to keep the charm of the slipper tub - but that might be the only answer for me right now. |
#4 |
Tile Contractor
Just make sure that if this is what you do, that you waterproof that shelf before tiling it. There's a good one at Home Depot called Redgard that you can roll on-- pretty easy to use.
#5 |
M D Tile
Redguard has always been a good product for me. Pro-red by C-cure and mapelastic by mapei are similar products that are easily troweled or painted onto the surface.
| Display Modes | |
| Tiling - what a nightmare | Richo | Flooring | 9 | 01-06-2008 09:02 PM |
| Ceramic Tiling on a Slab | nsb318 | Flooring | 3 | 03-01-2007 03:23 AM |
| Tiling inside a fireplace | Patricia | Building & Construction | 4 | 09-02-2006 08:51 PM |
| How scuffed should old tile be before tiling over w/ new | J187 | Flooring | 3 | 07-25-2006 09:01 PM |
| bathroom tiling | neptunian | General Discussion | 1 | 03-29-2005 08:44 AM |
