Tiles Are Up, Now How Should I Go About Removing This Plywood? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-08-2013, 12:04 PM   #1
Rewards Points: 384
Tiles are up, now how should I go about removing this plywood?
I want the floors level so I have to remove the plywood that was under the tile. It appears who ever put the file down (besides doing it incorrectly) used A LOT of screws and since it's been here for ~30 years most are rusted and wont come out. Should I just burn a balde on my circular saw and cut it into strips? I tried prying it up but my back hurts already.
Tiles are up, now how should I go about removing this plywood?-2013-06-08-12.00.06.jpg   Tiles are up, now how should I go about removing this plywood?-2013-06-08-12.00.17.jpg
RyanD is offline   Reply With Quote
Old 06-08-2013, 12:54 PM   #2
Rewards Points: 13,300
Going to need a Toe Kick saw for the outside edges, A sawalls for the outside corners and any place the Toe Saw will not reach. Then you can cut between the joist.
A Gutster bar will rip it right out.
Northern Tool sells them.
http://www.thegutster.com/
Old 06-08-2013, 02:13 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Joe,
The joists have nothing to do with this, he's removing the underlayment, not the subfloor.
Ryan,
How thick is that underlayment? What new flooring will you be installing and what's on the adjacent floors?
Jaz
Old 06-08-2013, 02:17 PM   #4
Rewards Points: 384
Originally Posted by JazMan View Post
Joe,
Ryan,
Jaz
It appears to be 1/2" I'm putting matching hardwoods all over thus the need to tear it up and level it with the other subfloor.
I tried slicing with a circular saw but it still takes a ridiculous amount of energy to pry it up after. There was to be a dozen screws per sq/ft. Crazy.
Old 06-08-2013, 03:01 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
You need the right tool, one that gives you leverage. But no one said it's gonna be easy.
Can we assume the subfloor is at least 5/8 or maybe 3/4" thick?
Jaz
Old 06-08-2013, 03:18 PM   #6
Rewards Points: 384
Jaz
Subfloor is 3/4". I have a 3' pry bar I've been using it's just those screws are really no match for it. No joke, a screw about every 2-3 inches most of which I can't see because of the left over thin set.
Old 06-09-2013, 09:49 AM   #7
Rewards Points: 222
seems to me, that you are going to have to make a zillion cuts. then pry up the little pieces.
Fix'n it is offline   Reply With Quote
Old 06-09-2013, 11:26 AM   #8
Pro
JetSwet's Avatar
Rewards Points: 502
A roofing shovel will work best in this case.
JetSwet is offline   Reply With Quote
Old 06-09-2013, 12:01 PM   #9
Rewards Points: 384
Yeah, this ain't working. 1.5 days of word and I've moved about 18".
Picking up the roofing shovel, we'll see if that helps.
Tiles are up, now how should I go about removing this plywood?-2013-06-09-09.54.27.jpg
The Following User Says Thank You to RyanD For This Useful Post:
JetSwet (06-09-2013)
Plywood floor tiles hyenas Flooring 12 12-13-2011 07:54 PM
Cracked Bathroom Floor Tiles klmeenan Tiling, ceramics, marble 26 07-30-2011 06:37 PM
removing mirror tiles from wall 19mquinn79 General DIY Discussions 1 03-14-2011 01:29 PM
removing wall tiles pyper Building & Construction 13 02-20-2011 08:19 PM
Removing vinyl self-stick tiles. Jim F Flooring 12 02-05-2011 07:44 AM
