-   -   Tiles are up, now how should I go about removing this plywood? (http://www.diychatroom.com/f5/tiles-up-now-how-should-i-go-about-removing-plywood-181490/)
RyanD 06-08-2013 12:04 PM
2 Attachment(s)
I want the floors level so I have to remove the plywood that was under the tile. It appears who ever put the file down (besides doing it incorrectly) used A LOT of screws and since it's been here for ~30 years most are rusted and wont come out. Should I just burn a balde on my circular saw and cut it into strips? I tried prying it up but my back hurts already. :whistling2:
joecaption 06-08-2013 12:54 PM
Going to need a Toe Kick saw for the outside edges, A sawalls for the outside corners and any place the Toe Saw will not reach. Then you can cut between the joist.
A Gutster bar will rip it right out.
Northern Tool sells them.
http://www.thegutster.com/
JazMan 06-08-2013 02:13 PM
Joe,
The joists have nothing to do with this, he's removing the underlayment, not the subfloor.
Ryan,
How thick is that underlayment? What new flooring will you be installing and what's on the adjacent floors?
Jaz
RyanD 06-08-2013 02:17 PM
Originally Posted by JazMan (Post 1197530)
Joe,
Ryan,
Jaz
It appears to be 1/2" I'm putting matching hardwoods all over thus the need to tear it up and level it with the other subfloor.
I tried slicing with a circular saw but it still takes a ridiculous amount of energy to pry it up after. There was to be a dozen screws per sq/ft. Crazy.
JazMan 06-08-2013 03:01 PM
You need the right tool, one that gives you leverage. But no one said it's gonna be easy.
Can we assume the subfloor is at least 5/8 or maybe 3/4" thick?
Jaz
RyanD 06-08-2013 03:18 PM
Jaz
Subfloor is 3/4". I have a 3' pry bar I've been using it's just those screws are really no match for it. No joke, a screw about every 2-3 inches most of which I can't see because of the left over thin set.
Fix'n it 06-09-2013 09:49 AM
seems to me, that you are going to have to make a zillion cuts. then pry up the little pieces.
JetSwet 06-09-2013 11:26 AM
A roofing shovel will work best in this case.
RyanD 06-09-2013 12:01 PM
1 Attachment(s)
Yeah, this ain't working. 1.5 days of word and I've moved about 18". :furious:
Picking up the roofing shovel, we'll see if that helps.
