Tiles Selection For Coffee Shop - Flooring - DIY Chatroom Home Improvement Forum
Old 12-06-2012, 11:07 PM   #1
tiles selection for coffee shop
Hello,
I am trying to select tiles for floor in coffee shop.
Cannot get any useful info about standards types. etc
How to determine if it should be commercial brand?
does PEI III and ADA complaint will be enough?
Help please!
DoingMySelf is offline   Reply With Quote
Old 12-07-2012, 05:06 AM   #2
DIY staff
Rewards Points: 7,174
Main concern for you is strength--slip resistance and clean ability---
Look for a porcelain tile---with a washable glaze that will not be slippery when wet---
Also seriously consider using epoxy grout so the grout is easy to keep clean---that may be a requirement by your local health department.
Old 12-07-2012, 07:45 AM   #3
Rewards Points: 5,974
I totally agree with Mike and any good tile store should be able to point you in the right direction, not a big box store.
Old 12-07-2012, 07:55 AM   #4
Rewards Points: 150
Look for glazed porcelain tiles. They are hard and non-absorbent. I would consider at least a PEI class 4 for a coffee shop.
Class 0 - No Foot Traffic: Wall tile only and should not be used on floors.
Class 1 - Very light traffic: Very low foot traffic, bare or stocking feet only. (Master bath, spa bathroom).
Class 2 - Light Traffic: Slipper or soft-soled shoes. Second level main bathroom areas, bedrooms.
Class 3 - Light to Moderate Traffic: Any residential area with the possible exception of some entries and kitchens if extremely heavy or abrasive traffic is anticipated.
Class 4 - Moderate to Heavy Traffic: High foot traffic, areas where abrasive or outside dirt could be tracked. Residential entry, kitchen, balcony, and counter top.
Class 5 - Heavy Traffic: Ceramic tile suggested for residential, commercial and institutional floor subjected to heavy traffic.
zakany is offline   Reply With Quote
Old 12-07-2012, 08:00 AM   #5
more info
The issue I have that 50% of the floor was already covered with tile about 400 sqf, I have to add 350 sqf of black + white "chess board" tiles.
the size of the current tile is 8x8 and looks like was installed long time ago with grout gap 1/4" or more
I want to add tiles on top of old vinyl tiles as they are were difficult to remove.
Searching for tiles locally in Cleveland , OH now
need more advises, please
Old 12-07-2012, 08:11 AM   #6
I could be wrong but if I remember correctly (probably not) the old 8x8 vinyl tiles were asbestos so you are correct to just go over them and not remove them. I don't believe you can get an 8x8 ceramic tile and if the others are quite old they wouldn't come close to matching. But again I might be wrong. Some one will be along to let us know.
Old 12-07-2012, 09:29 AM   #7
FOUND ONLY THIS ONE close to my location
http://www.flooranddecoroutlets.com/s11101665.html#
I have found only this one available close to my place.
it will be VERY low traffic as no customers will be inside the place and only 2 employees.
Old 12-07-2012, 10:50 AM   #8
Rewards Points: 150
If you have asbestos tiles, you'll want to encapsulate them. Don't remove them, don't drill through them.
Old 12-07-2012, 11:05 AM   #9
Doing I used to live in ygst. so I'm pretty sure there are places around clev. this is not really a specialty item . Maybe broaden your search some will help.
Old 12-07-2012, 12:35 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 388
From the description and price of that 8x8 tile I highly recommend you keep looking. That appears to be regular ceramic, probably made from brown or reddish bisque, not very durable.
Although you say there is very little traffic, I will bet those few employees are standing and pivoting on a few small areas which may be worse than large commercial areas.
Installing ceramic over VTC is not a good idea, but can be done if all the tiles a stuck for good. Problem is it's very unlikely all the tiles are well bonded. Especially check around the perimeter.
Old vinyl composition and vinyl asbestos tiles never came 8x8". The real old ones were 9x9, (including asphalt tiles), most were 12x12".
Jaz
The Following User Says Thank You to JazMan For This Useful Post:
ToolSeeker (12-07-2012)
Old 12-07-2012, 01:48 PM   #11
Rewards Points: 150
I'm used to encountering 9x9 asbestos tiles. Where I work was built starting in the 1940s. If you figure everything was painted with lead and coated with asbestos, you're probably right.
Old 12-07-2012, 02:59 PM   #12
found tiles Glazed ceramic on spec list mentioned for light commercial floor.
vinyl tiles I have are 12x12 only ceramic 8x8.
I will post photos later as now I have another issue to decide about how to make a transition from old to new area as I have mentioned the grout gap in the old install is VERY wide even may be 1/2"
Thanks everybody for help!
Old 12-07-2012, 09:02 PM   #13
Here the current condition, looking for an advise how to make a transition from old to new tiles. I do not like that wide grout gap!! what to do 1/8" not more.
Armstrong Alterna heavy tiles in bathroom DiegoJames Flooring 17 04-15-2013 04:40 PM
help! why do the tiles in my bathroom crack? diy'er on LI Flooring 35 11-02-2009 11:39 AM
How to/what to use to cover potentially asbestos tiles? TomServo Flooring 7 09-10-2009 11:59 AM
How to cut 16 x 32 Floor Tiles & Trowel size to use atm Tiling, ceramics, marble 3 09-08-2009 07:48 PM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 01:04 AM
