Old 07-04-2011, 06:11 PM   #1
tiles over tiles
can i tile a floor over tiles and what should i use
mary doyle is offline   Reply With Quote
Old 07-04-2011, 06:28 PM   #2
Pro Flooring Installer
rusty baker's Avatar
tiles over tiles
What kind of tiles? Ceramic over ceramic? Vinyl over vinyl? Ceramic over vinyl? Vinyl over ceramic?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 07-04-2011, 06:29 PM   #3
Super Moderator
tiles over tiles
Yes,maybe.
Ceramic tile can be installed over the top of existing ceramic--IF-the original tile is sound and properly installed. (some times it's not--cracks,loose grout--all indicate failure)
The old tiles need to be cleaned of all dirt,oils and wax--roughed up a bit if shiny--a grinder with 60 grit sand paper is handy.
Use a two part thinset --powder and liquid latex--Kerabond and Keralastic by Mapei is a good example of a two part thinset.----Mike---
Old 07-05-2011, 02:39 PM   #4
Stuck in the 70's
Blondesense's Avatar
tiles over tiles
Carefully think through how adding to the height of the floor will affect things. If you have an exterior door that swings in over the tile, how will you deal with the threshold? Even interior doors may need to be cut down.
Old 07-05-2011, 03:06 PM   #5
tiles over tiles
Like I said before. Without more info, no way to answer.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
6"x6" porcelain tiles?????? Quickdraw Flooring 15 12-04-2009 07:29 AM
calking backer board to tub glassman General Discussion 13 06-19-2008 09:41 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
