Old 06-03-2008, 10:36 AM   #1
Question
tiles around a bath tub
once i build a frame for my recessed bath tub that comes with one of those exposed walls (not sure the exact name you call it), should i first put tile on the floor to go all the way to the 2x4 sole plate and then the tub over it (so that the tile actually reaches under the lip of the tub) or the tub first all the way down to the uncovered floor (concrete in this case as it is a basement apartment) and then tile to reach the edge where it meets the tub ?
thx,
- a -
Old 06-03-2008, 10:45 AM   #2
K&B Remodeler/Tile Guy
angus242's Avatar
Tub first
Angus
angus242 is offline   Reply With Quote
Old 06-03-2008, 11:15 AM   #3
Moderator
Termite's Avatar
Tub first. Angus is right!
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
Complex challenge with bath exhaust fan - need help with solution! Honest Bill Electrical 6 11-02-2007 03:52 PM
TrafficMaster grout f.y.i. denman Flooring 16 07-01-2007 04:07 PM
Shower Tiles Easily Pop Out - Bad Installation? kabowma0 Remodeling 6 04-23-2007 08:43 PM
Vinyl Tiles over pre-existing layers Thwiipp Flooring 1 09-05-2006 02:10 PM
