Old 10-18-2009, 06:01 PM   #1
Default tileing bathroom floor
Im goin to tile my bathroom floor in the basement,no rock up yet.Is it better to tile before rocking? or after? or does it even matter?
ron0805 is offline   Reply With Quote
Old 10-18-2009, 07:25 PM   #2
After.
R&D Tile is offline   Reply With Quote
Old 10-18-2009, 07:34 PM   #3
Y
Originally Posted by R&D Tile View Post
After.
Y after? Does it really matter?
Old 10-18-2009, 07:49 PM   #4
Residential Remodeler
A lot of site prep on your part to make sure no drywall is dropped, drug, etc. on new tile and to make sure no joint compound gets in all the new grout.
Rock, mud, sand if necessary, throw a coat of primer on, maybe 1 top coat, then tile. Eliminates all the need for floor protection.
CookeCarpentry is offline   Reply With Quote
Old 10-18-2009, 11:58 PM   #5
thx thats the kind of answer i wanted.What about the vanity? before or after?
Old 10-19-2009, 07:43 AM   #6
After the tile.
Old 10-19-2009, 12:55 PM   #7
After the tile.
thx ill do that
Old 10-19-2009, 05:56 PM   #8
Set fixtures after the tile - prevents damaging the cabinets when installing tile.
Also, should you ever swap out the vanity cabinet, you will not have to worry about exact size, as you will have tile underneat.
Old 10-20-2009, 12:09 AM   #9
thx it makes sense
Old 10-21-2009, 11:47 AM   #10
After the tile.
i hav to cut 1 tile around the toilet flange i dont want to spend much money on a tool to cut it as its only 1 tile with a circle.Will a glass cutter work then i can break it off in small pieces?
Old 10-21-2009, 04:19 PM   #11
Try a tile nipper.
JK Floors is offline   Reply With Quote
More On This Topic
Hi. I'm Jen from Clay Cafe and on behalf of Expert Village. I'll be showing you how to take your ceramic piece from start to finish. In this clip I'd like to talk a little bit more about what glaze actually is. Glaze is essentially liquid glass that when... Read More »
Introduction to Pottery
Introduction to Pottery by Expert Village
Hi. I'm Jen from Clay Cafe and on behalf of Expert Village I'll be showing you how to take your ceramic piece from start to finish. In this clip we will be learning about how to paint on pottery. The first step for painting on pottery is picking your... Read More »
Hi. I'm Jen from Clay Cafe and on behalf of Expert Village I'll be showing you how to take your ceramic piece from start to finish. In this clip I'd like to actually show you what a piece looks like when it goes through the different stages. When people... Read More »
Hi. I'm Jen from Clay Cafe and on behalf of Expert Village I'll be showing you how to take your ceramic piece from start to finish. In this clip I'd like to introduce you to what glazes actually out there that you can paint your piece with. First off the... Read More »
Hi, I am Jen from Clay Cafe and on behalf of Expert Village I'll be showing you how to take you're ceramic piece from start to finish. Once a piece has been painted and the design is complete, the next the pieces going into the processing stage. To start... Read More »
Removing concrete slab on 3rd floor bathroom NowItsShowtime Flooring 2 03-26-2009 04:17 PM
Bad spots on Bathroom floor part two! Steph Flooring 0 03-05-2009 11:55 PM
small bad spot on bathroom floor Steph Flooring 4 03-05-2009 11:43 PM
Bathroom Floor - Tile - floor Height - Flange DoItYourSelfer5 Flooring 2 12-15-2008 08:18 PM
Leaking bathroom floor patatura Flooring 6 12-06-2008 08:30 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
