Tiled Basement Shower Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 02:05 PM   #1
Hi guys,
I'm putting a shower in the basement in an area where the floor already slopes towards an existing drain. I'm wondering what the recommended installation procedure is here? I'm assuming I can skip the pre-slope since the floor is already sloping towards the drain? Would I proceed with the PVC or CPE liner directly on the floor and then the top layer of deck mud?
Is it at all acceptable to use a clear coat sealer on the concrete instead of the plastic liner and then install ceramic tiles directly on that?
Thanks!
CB55
Coolboy55 is offline   Reply With Quote
Old 11-07-2012, 03:01 PM   #2
DIY staff
Rewards Points: 7,174
Post a picture if you can----
there are three popular methods of building a pan----
Deck mud with a PVC or Rubber liner----
Deck mud or Styrofoam pan with surface membrane---(Schluter Ditra) and others
Deck mud with a paint on membrane----Hrdroban by Latacrete----How to build a shower - Building a shower pan with pre-sloped mortar bed, liner and curb.
Latacrete and Schluter have sites and Youtube is loaded with both companies videos.
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 08:51 PM
Options for Cold Basement Concrete Floor? jefferis Flooring 16 12-09-2009 12:23 PM
New drains under the basement floor, guidance needed mason Plumbing 6 01-10-2009 04:58 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
Tiled shower floor kilty Kitchen & Bath Remodeling 1 10-29-2008 10:18 AM
