Tile To Wood Floor Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 02-17-2013, 11:09 PM   #1
Rewards Points: 24
Tile to wood floor transition
I know this has been discussed ad nauseum...
I'm planning on doing porcelain tile and bamboo hardwood flooring. The wood run horizontal to the tile. I'd prefer not to use a wood t molding for aesthetics. I will adjust the height difference with the schluter ditra on the tile so I should be able to make the height even. I looked at http://www.schluter.com/2171.aspx and http://www.schluter.com/1_3_reno_t.aspx and both could be an option. My question is about the wood's expansion and contraction. How close can I put the wood to the transition? Should I use flexible caulk between the wood and the transition or the transition and the tile or on both side? I live in the desert so we probably have less weather changes so more even humidity.
Thanks for the advice...
Chris
Forgot to mention. substrate is concrete so wood will be glued down....
stupid48 is offline   Reply With Quote
Old 02-18-2013, 12:29 AM   #2
Rewards Points: 6,652
You have to use a transition between the two materials, or use a silicone based caulk colored the same color as your grout, but it will end up looking real bad if you do not do it perfect.
Old 02-18-2013, 11:31 AM   #3
Rewards Points: 3,520
" My question is about the wood's expansion and contraction. How close can I put the wood to the transition"
The expansion and contraction rate for bamboo is 50% of wood,so half of 3/4" is 3/8" and being in the desert maybe a little less.
Canarywood1 is offline   Reply With Quote
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 08:03 PM
Tile or wood baseboard in a home? Wahbehwoo Remodeling 4 09-27-2012 09:40 PM
Ceramic Tile or Laminate Wood Flooring PearlWhiteGT Flooring 5 01-10-2012 01:56 PM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 10:56 PM
