Old 03-04-2006, 05:12 PM   #1
Exclamation Tile Walls - Wood Floors - which goes first?
Hi Folks,
Small dilemna. I have new walls and flooring going in and would like to make sure the finished edges look right. Around the tub and the custom shower, tiles will be placed on the vertical walls where they meet the floor.
I have subfloor right now and will be installing bamboo flooring.
Question - Should the flooring go down first and then match the tiles to the top of the flooring? OR should I put the tiles on first, then match the flooring to the vertical face of the tiles?
Thanks!
MikeinBurien
MikeinBurien is offline   Reply With Quote
Old 03-04-2006, 08:55 PM   #2
Super Moderator
Floorwizard's Avatar
you cannot butt the wood up to the tile because you would need some molding to cover up the edge. and the tile is acting as a molding right?
so install the wood first.
floating or nail down?
Time to ride again!
Floorwizard is offline   Reply With Quote
More On This Topic
Okay now we’re going to talk a little bit about floorings. One flooring a lot us have in our homes that we don’t even know we have and we can utilize is a concrete slab. A concrete slab, you can strip your wall to wall carpeting and take the... Read More »
The biggest challenge in decorating your home is finding out what really is good. There are a number of products on the market that are extremely toxic and in my mind should not be sold to the public. Products that they know have formaldehyde and all... Read More »
Hi! I'm Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a quality assurance walk through on this house. The same thing on this tile we were talking about over here, look for that same thing in your... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com. In this segment I am going to be showing you how to do a dry run with your tile to make sure the layout is working. As you can see we have snapped our lines and what you can do if... Read More »
How to Trim Tile
How to Trim Tile by eHow.com
Applying tile to a room can add interest as well as accentuate architectural details. Choosing the right tile for trim is very important and can add the proper finishing touch that makes or breaks a project. Read this article to learn more. Read More »
Tile vs Wood as a baseboard MattCoops Flooring 12 05-27-2009 05:39 PM
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 06:21 PM
Radient floors under tile mjhlakestclair Flooring 6 12-10-2008 11:14 PM
Need some advice on how to remove ceramic tiles over wood floors. sandman512 Flooring 4 09-02-2007 01:03 PM
Washing my wood floors J187 Flooring 1 11-15-2006 12:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
