Tile Wall To Tile Floor Plus Wood Baseboard - Flooring - DIY Chatroom Home Improvement Forum
Old 08-21-2012, 12:47 PM   #1
Tile Wall to Tile Floor plus Wood Baseboard
Hi, i just installed a new Sterlng tub/shower surround. I am going to put a 3inch bullnose down both sides (vertical) for a nice border effect (the rest of the walls is just normal painted sheetrock). The floor is matching 12x12 tile.
Should the tile border go all the way to the floor or do I stop at the wood baseboard?? Im concerned the wood base board bumping up the bullnose...
hollywood33 is offline   Reply With Quote
Old 08-21-2012, 01:31 PM   #2
Rewards Points: 12,812
Post a picture.
In most cases I'd suggest going to the floor.
I'd Cut the base long, slide it in place, and use a sharp pencil to mark along the bull nose, remove it and make a 45 deg. cut to that line. What that will do is leave a flat area where it touches the tile but have a back angle so it does not make the base look like it's sticking out out.
Then you make another mark on the back side of the base so you can cut it to fit the outside corner.
Wood baseboard and tile flooring Dave613 Flooring 1 06-02-2011 08:24 AM
click lock wood flooring and tile guessingo Flooring 3 09-15-2010 11:56 PM
Need help with wood retaining wall idesign2 Landscaping & Lawn Care 2 08-12-2010 05:29 PM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 07:22 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 11:05 AM
