Tile Underlayment - Flooring - DIY Chatroom Home Improvement Forum
Old 09-12-2008, 01:45 PM   #1
Tile Underlayment
Quick sanity check because I obviously don't do this every day.
Existing subfloor is 3/4" Advantech OSB glued and nailed to 2x8 joists 16" OC.
To get the height right and prep for tile I was going to:
1) Screw down a layer of 3/4" BC plywood. No glue; no T&G; same direction as subfloor, offset joints; I plan to use 2" screw to fully penetrate existing subfloor over the joists.
2) Layer of 15# tar paper.
3) Screw down a layer of 1/2" Hardibacker bedded in thinset. Alkali resistent screws to penetrate both the ply and OSB.
Is my memory serving me right or am I suffering from another "senior moment"?
Thanks.
Sam
samjack is offline   Reply With Quote
Old 09-12-2008, 03:51 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 388
Like me....you're getting older Sam!
With two layers of 3/4" you're going to have a very solid floor, from joists to joists, anyway. Please go down and measure the unsupported span of the joists. Measure from one support to the other, face-to-face. This is important.
1. Good plan. 1 3/4" screws, even better.
2. Absolutely NO tarpaper. Where did that come from?
3. OK, but change to rust resistant screws, alkaline resistant mesh tape and thinset. No need for 1/2" backer, 1/4" is for floors, but if for height, OK. No need to penetrate the OSB at all or much. Use the special Hardi screws.
Jaz
JazMan is online now   Reply With Quote
Old 09-12-2008, 03:59 PM   #3
Jaz
Wouldn't 1 1/2 or 1 1/4 scres work as well? I always thought that when laminating underlayments, you did not want to penetrate into the floor joists.
jerryh3 is offline   Reply With Quote
Old 09-12-2008, 04:35 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 388
Glad you brought that up. Inch and a quarter would definitely NOT work very well. Only penetrate the sub by 1/2", YIKES that would be a disaster. Plus there is NO lamination going on here.
Inch and a half would be much better. Problem is that the first 1/8-1/4" of the screw is pointed, which does nothing once set. I recommend going a little longer for max bite. Especially when the sub as in this case is OSB, which does NOT hold a screw as good as plywood.
Also most CBU companies like you to use a screw that is 1/4" "too long" simply to verify fasteners placement in case of a complaint someday. Quarter or 1/2" penetration of the joists does nothing, no affect.
Jaz
Old 09-12-2008, 04:47 PM   #5
The joist span is under 8 feet. I remembered to include the joist size and spacing so I wouldn't be reminded to check that but neglected to include the span. Doh!
Which is the only reason I would go over the joist. I have a nasty scar on top of my head from an errant nail.
The 1/2" CBU is to get the height only.
Tarpaper? Why did we do that? I have no idea. Maybe we did that over 5/4 diagonal planking. Or maybe that was how cavemen uncoupled tile from the underlayment. At anyrate, I'll skip the tarpaper.
Alkali tape. That's it! I told you I was getting old. I'll use the Hardi screws.
Thanks for keeping me straight.
-Sam
Old 09-12-2008, 04:49 PM   #6
Jaz
By lamination I just meant one layer going over the subfloor. Good expanation of the screw requirements. One thing though, I know the Backer-On screws come in 1 1/4 and 1 5/8. How can they expect penetration through the CBU and 1 1/4 to 1 1/2 of flooring to verify screw placement?
Old 09-12-2008, 05:01 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 388
The screws won't penetrate in this case because of 2 layers of 3/4", you're right. Most of the time the CBU goes over a single 3/4".
So, in this case Sam should use 1 5/8" or use roofing nails instead. My choice is roofing nails, works great, faster, cheaper. Plus you can easily drive them flush.
Jaz
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Best option for underlayment under a tile floor. Weathermaker01 Flooring 8 06-20-2008 10:08 AM
Underlayment height for tile / carpet.... scheenstra Flooring 2 04-23-2008 12:12 AM
Tile underlayment - mortar bed question Richo Flooring 10 01-01-2008 05:54 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
