Old 09-26-2008, 12:21 AM   #1
Tile under the shower?
I am going to put ceramic tile in a 5'x7' bathroom that currently has a vinyl floor (that we put in about 12 years ago) and I have to also replace the shower since my ex-husband didn't do such a hot job putting in the kit. I am thinking about an acrylic base with tiled walls, but I need to know if I should tile all the way up to the drain and set the new shower base ON the tile or just up to the where the shower will be.
Lynn_Rich is offline   Reply With Quote
Old 09-26-2008, 08:56 AM   #2
Moderator
Termite's Avatar
Hmmm. An acrylic shower base is a great way for a DIYer to build a shower floor. No, you don't tile under them. You strip any tile or flooring off, down to bare plywood. You then would have a pretty good amount of re-plumbing on your hands...Removal of the old drain and tying in the new drain to the new pan. You then tile the walls on top of properly waterproofed cement backerboard.
You cannot take an existing tile shower and add a pan without total demolition of the existing base and at least partial demolition of the current wall tiles at the bottom.
Old 09-26-2008, 09:39 AM   #3
Thanks. I don't have tile there now, it's just a lousy-looking fiberglass surround kit and I am anticipating having to replace drywall, as I suspect it might be damp back there (Ex-husband's shortcut-installed right on reg. drywall). I also figured I would have to redo the drain, as it does leak from time to time and I am getting a real plumber for that. I was just concerned that there might be an issue with that little lip on the bottom of the new pans interfering with the tile, but I suppose I could just caulk/grout that, eh?
Tags
bathroom tile question, shower drain, tile
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Building a tile shower ghostrider20 General Discussion 2 03-01-2007 09:54 PM
Shower tile need some help here dirtyb115 Remodeling 2 12-23-2006 01:27 PM
