Tile Under Kitchen Cabinets - Yay Or Nay ? - Flooring - DIY Chatroom Home Improvement Forum
Old 04-21-2008, 02:45 PM   #1
Rewards Points: 1,062
Question
tile under kitchen cabinets - yay or nay ?
i am getting ready to do my kitchen floor, which will be tile, but was thinking that a large chunk of the area will be covered by cabinets so why bother with tedious and expensive tiles if something less sightly yet equally functional can be substituted for cheaply ?
pros, cons, and what would THAT be ?
thanks,
- a -
Old 04-21-2008, 02:50 PM   #2
Custom Cabinet Maker
If you are going to keep the same cabinets forever,never change anything,and you put the same thickness UNDER them of a different color etc then fine. I dont think it is worth it, you arent saving a thing labor wise,plus you now have to work MORE to be sure where you change over is FULLY HIDDEN and make super sure you dont grab wrong tile in the field and mess it all up
skymaster is offline   Reply With Quote
Old 04-21-2008, 03:46 PM   #3
Question
thanks but WHAT is that cheap flooring cover that i would substitute for in the hidden area ?
thanks,
- a -
Old 04-21-2008, 03:47 PM   #4
Rewards Points: 150
If it's a DIY project, the cost savings may not be too much... I think it's just a cleaner install if you tile underneath. Alos provides flexibility IF you need to change the layout in a few years time.
slakker is offline   Reply With Quote
Old 04-21-2008, 04:15 PM   #5
Talking
thanks. y'all have convinced me - tile all the way !
Old 04-21-2008, 05:21 PM   #6
Question
beta on workforce 550 tile cutter
the one that can be found at HD ? i believe $88. does it fit the bill for DIY and, if not, what should i be investing in ? i don't mind spending on quality tools as i see myself progressing in this line of interest past DIY eventually.
thanks,
- a -
Old 04-21-2008, 05:22 PM   #7
Unhappy
sorry, disregard my last post
sorry
Old 04-21-2008, 06:10 PM   #8
Nah we cant just ignore ya
Old 04-22-2008, 08:01 AM   #9
Homewrecker
B Parker's Avatar
thanks,
- a -
I am currently using the $88.00 saw on 18" porcelain, I find it to do ok, it does chip a bit on the edges, but 99.9% of my cuts are going to be covered by trim. I'm happy with what it's doing on this job so far, have laid about 200sqft with it.
If you are looking to do more than diy home projects, I do not think it will be what you are looking for in the long run
B Parker is offline   Reply With Quote
Old 04-24-2008, 07:09 PM   #10
Homewrecker
B Parker's Avatar
It's a Workforce THD550 cheapo from Home Depot. $88.00.
Old 04-25-2008, 01:56 PM   #11
I have the same saw and have put down around 400 sq ft. The saw is fine the blade it comes with is junk. If you buy this saw get a better blade.
Bcoleman6 is offline   Reply With Quote
Old 04-29-2008, 01:42 PM   #12
Mold!! Let's kill it!
Rewards Points: 2,012
I ran the tile under my kitchen cabinets and now I wish I hadn't. I want to replace the tile and will have to try to cut them back flush with the toe kick. It would have been easier to cut the tile to the toe kick to begin with.
Cabinets over tile, or tile around cabinets??? harleysilo Remodeling 10 11-02-2012 02:25 PM
Are kitchen cabinets standard sizes? Yeti Remodeling 8 01-30-2009 03:20 AM
Installing kitchen wall cabinets higher than spec recommendation? alexz General DIY Discussions 14 07-21-2008 12:32 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 04:21 PM
Kitchen Cabinets and Walls ththomps Remodeling 4 09-18-2006 11:23 PM
