Tile Under Door Frame? - Flooring - DIY Chatroom Home Improvement Forum
Old 06-26-2013, 02:04 PM   #1
Rewards Points: 198
Tile under door frame?
I'm getting ready to install floor tile in my bathroom. I used self-leveler on the floor. I did this before I cut out the bottom plate for the doorway, so I could use the bottom plate as a dam. However, now there is about a 1/4" drop from the bathroom floor to the existing floor.
Should I run the tile to the point under the door so under the closed door is tile? How do I make up for that drop--thinset OK for that small area? Or should I title to where the self-leveler ends and use a threshold for under the door?
btw, the door is not installed yet, so I can cut the jambs as needed.
Thanks for any help.
benleef is offline   Reply With Quote
Old 06-26-2013, 02:30 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 14
Pictures?....
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 06-26-2013, 02:43 PM   #3
Rewards Points: 198
Sorry for the horrible explanation. Haha. I'm not at home right now and don't have a picture, but I drew a picture to help visualize the issue. I can take a picture this evening. Thanks.
Old 06-26-2013, 02:47 PM   #4
Rewards Points: 1,450
By your description it doesn't sound like bull nose tiles (my first thought) will work, so a threshold is probably going to be needed.
I assume that 1/4" height difference is before you lay the tile?
ktkelly is offline   Reply With Quote
Old 06-26-2013, 03:00 PM   #5
Rewards Points: 198
Yes, the 1/4" height difference is before I lay the tile. How do I secure a threshold to the concrete floor?--construction adhesive? I would like to use wood, but since this is a basement, maybe I shouldn't use wood directly on the concrete....
Old 06-26-2013, 04:14 PM   #6
Newbie Bill
Rewards Points: 518
What is going to be on the floor outside the bathroom?
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is offline   Reply With Quote
Old 06-26-2013, 04:57 PM   #7
Rewards Points: 198
Right now it is going to remain concrete for the foreseeable future, eventually in the distant future I would like to do tile (it is a basement).
Old 06-27-2013, 11:20 AM   #8
Rewards Points: 198
Here are some pictures if that helps
Here are the pictures to give a better idea of my issue. I'm guessing some type of threshold will be best, but I'm not sure what kind to get and how to secure it to the floor.
Thanks for any advice.
Old 06-27-2013, 02:05 PM   #9
Davejss's Avatar
Rewards Points: 740
I would tile to the edge of your floor leveler and attach a threshold using Tapcons counter sunk and finished with plugs.
Davejss is offline   Reply With Quote
Old 06-27-2013, 02:09 PM   #10
Rewards Points: 198
Yes, that is what I was thinking about doing. Thanks
Old 06-29-2013, 11:03 AM   #11
Rewards Points: 274
I'm academic some blazon of beginning will be best, but I'm not abiding what affectionate to get and how to defended it to the floor.
Wooden floor Dallas
alexjoe is offline   Reply With Quote
Solving discontinued tile issue timbo59 Flooring 14 10-03-2012 09:03 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Removing Tile Over Hardwood: Need Help With Kitchen/Bath Creelove Flooring 3 02-01-2011 07:03 AM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
