Tile Subfloor - Flooring - DIY Chatroom Home Improvement Forum
Old 04-15-2011, 10:11 AM   #1
Tile Subfloor
I am putting ceramic tile in my kitchen. I have the floor stripped to its original 3/4 X 5 1/2 planks (actual size) over 16" on center joists. Can I put cement board directly over this, or do I need additional plywood or something over that. I would like to stay near my present height so as to not make the kitchen floor too much higher than the surrounding floors.
tonynace is offline   Reply With Quote
Old 04-15-2011, 05:46 PM   #2
Handyman
Rewards Points: 512
If you are worried about the height difference you can lay down some exterior ply with wire mesh. First you have be sure that the floor boards are screwed down tight to the joists. Then use wood floor screws to secure the plywood down, and I mean screw the life out of it...6" min. on the joists and 2 to 4" on seams. Be sure to stagger the ply seams. Attach the mesh with galvanized staples or roofing nails. When you put the mesh down, be sure not to crush it by walking on it..use knee pads to prevent compression. Expect your tile thinset to vary in thickness as you install the tile and level as you go with a 4 ft level.
canadaclub is offline   Reply With Quote
Old 04-15-2011, 07:07 PM   #3
Rewards Points: 1,520
I think one of the tile pros will weigh in; it was my understanding that the underlayment was not to be screwed to the joists, only the subfloor. Also, the wire mesh is not a recommended part of tile laying (although done frequently).
bob22 is offline   Reply With Quote
Old 04-15-2011, 07:55 PM   #4
Handyman
Rewards Points: 512
I am sure Bud and the rest will chime in also as I hope they will. but IMO there is no underlayment, strictly a substrate for tile adhesion, I suppose the OP could use ditra as well but the idea is to create a sound base over the existing floorboards while providing an even transition to the adjoining floor.
Old 04-15-2011, 11:25 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
Wire mesh is not accepted by any tile organization.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 04-16-2011, 07:08 AM   #6
DIY staff
Rewards Points: 7,174
Skip the wire mesh--there are better ways---
Old 04-16-2011, 10:49 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
XXX
Thin set vs mesh porcelain floor tile over plywood subfloor and vinyl flooring Jerseygirl Tiling, ceramics, marble 49 05-23-2013 02:04 PM
laying stamped concrete over old tile Kimmarie Flooring 24 03-20-2012 01:20 PM
Tile after new subfloor Subcooled Flooring 8 02-20-2011 11:57 AM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Help with tile on subfloor please ddmnkf Tiling, ceramics, marble 11 09-26-2009 07:21 PM
