Tile Shower Bench - Flooring - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 09:04 PM   #1
Rewards Points: 212
Question
tile shower bench
when doing a kerdi shower with a bench is it better to kerdi the shower and thinset th bench to the kerdi? or to build the bench and wrap the wall and bench with kerdi?
bluebird5 is offline   Reply With Quote
Old 02-11-2011, 09:19 PM   #2
woodman58's Avatar
woodman58 is offline   Reply With Quote
Old 02-11-2011, 10:36 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 290
Is there something I'm missing in your question? In the end you want both waterproofed. What type of bench? Also depends on shape and its location. There's several variables.
Jaz
JazMan is online now   Reply With Quote
Old 02-13-2011, 05:18 PM   #4
Rewards Points: 212
wrapping bench in kerdi
Well I would either use concrete block or wood frame wraped in cbu. I realize the cbu would need to be wrapped. I am wondering specifically if it makes a difference wrapping a shower and then putting a waterproof bench on the ditra if water were to penetrate the tile and reach the ditra and run down the wall if it would get trapped under the bench. The other scenerio is that the water penetrates the tile runs down the wall across the top of the bench and down. Is that better than water running down the wall and behind the bench and under it and to the drain? The location would be along the back wall of the shower the full shower width.
Old 02-13-2011, 07:51 PM   #5
Tileguy
JazMan's Avatar
Rewards Points: 290
How did Ditra enter this conversation?
I would build the bench and then waterproof it. You do not want water behind the blocks if you go that way.
Jaz
Old 02-13-2011, 09:08 PM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
http://www.innoviscorp.com
XXX
Old 02-13-2011, 10:35 PM   #7
Rewards Points: 212
lol sorry i mean kerdi
Jaz
haha i meant kerdi
shower tile question aumanpj Remodeling 6 01-18-2011 06:34 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Another newbie building a tile shower ChadC Building & Construction 7 08-25-2008 03:58 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 09:19 PM
Building a tile shower ghostrider20 General DIY Discussions 2 03-01-2007 09:54 PM
