-   -   tile shower bench (http://www.diychatroom.com/f5/tile-shower-bench-95207/)
bluebird5 02-11-2011 08:04 PM
tile shower bench
when doing a kerdi shower with a bench is it better to kerdi the shower and thinset th bench to the kerdi? or to build the bench and wrap the wall and bench with kerdi?
woodman58 02-11-2011 08:19 PM
JazMan 02-11-2011 09:36 PM
Is there something I'm missing in your question? In the end you want both waterproofed. What type of bench? Also depends on shape and its location. There's several variables.
Jaz
bluebird5 02-13-2011 04:18 PM
wrapping bench in kerdi
Well I would either use concrete block or wood frame wraped in cbu. I realize the cbu would need to be wrapped. I am wondering specifically if it makes a difference wrapping a shower and then putting a waterproof bench on the ditra if water were to penetrate the tile and reach the ditra and run down the wall if it would get trapped under the bench. The other scenerio is that the water penetrates the tile runs down the wall across the top of the bench and down. Is that better than water running down the wall and behind the bench and under it and to the drain? The location would be along the back wall of the shower the full shower width. :huh:
JazMan 02-13-2011 06:51 PM
How did Ditra enter this conversation?
I would build the bench and then waterproof it. You do not want water behind the blocks if you go that way.
Jaz
Bud Cline 02-13-2011 08:08 PM
http://www.innoviscorp.com
bluebird5 02-13-2011 09:35 PM
lol sorry i mean kerdi
Jaz
haha i meant kerdi
