Tile Or Sheet Vinyl Over SLC - Flooring - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 08:00 AM   #1
Tile or sheet vinyl over SLC
I am in the process of finishing a small 1/2 basement bath. I have poured self leveling concrete to get a flat and level surface...well almost. when I run the level accross the width of the room everything is level. However, there is a small low spot (maybe 1/16 to 1/8"). I was thinking about installing tile (hoping that I could use the thin set to build up that area). My other option I was thinking of was floating sheet vinyl. My questions are;
1. Are there any issues with installing tile or vinyl directly over the SLC?
2. Will the thin set make up for that small low area or am I asking for trouble?
I dont want to apply more SLC if I can help it because unless you lay the level down you would never know there was a low spot.
Jesse
oba97 is offline   Reply With Quote
Have this sheet vinyl floor asbestos tested? CoconutPete General DIY Discussions 11 01-21-2012 10:39 PM
Vinyl sheet flooring & allure klmeenan Flooring 11 05-28-2011 12:39 PM
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Sheet vinyl seam separating tmpyankee Flooring 11 08-30-2008 08:28 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
