Tile Saw Blades? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-19-2008, 06:01 PM   #1
Fixer-'til-broker
DIYtestdummy's Avatar
Rewards Points: 262
Tile saw blades?
I had to buy a Turbo saw blade, since the continuous diamond blade chipped my porcelain tile horribly. The blade still chips the edges. What are some good wet saw blades to use that don't chip?
"Aw! Why does everything that only happens to stupid people happens to me?" - Homer J. Simpson
DIYtestdummy is offline   Reply With Quote
Old 08-19-2008, 06:58 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
May not be the fault of the blade.
Old 08-20-2008, 09:57 AM   #3
Fixer-'til-broker
Rewards Points: 262
I thought so too, but I've done everything suggested to me including making a cheater cut at the end (helped with the big corner chips) and I still get chips. The saw itself needed tweeking and balancing. The new blade works better, but still chips. I figure I can hide it once I grout and most of the bad edges will be covered by baseboard.
Old 08-21-2008, 11:40 AM   #4
Sorry to refer you to another board, but I'd ask the guys over at JB forums:
http://www.johnbridge.com/vbulletin/index.php
Tell them what type of saw you're using, type of blade and where you got the porcelain tile. They know their stuff.
jimithing78 is offline   Reply With Quote
Old 08-21-2008, 05:36 PM   #5
Fixer-'til-broker
Rewards Points: 262
Ah geez, why didn't I think of JB in the first place? Thanks!
It's a little late, but now my problem is how to tile over a step to where it looks nice. I'd like a rounded edge rather than a sharp 90* where the tiles meet. Any thoughts?
Old 08-21-2008, 08:44 PM   #6
Tile Contractor
Bill_Vincent's Avatar
If it's thru body porcelain, you can bullnose the edges of the tiles. If not, try using something from Schluter, like either their Rondec bullnose strips, or their STEP Rondec. strips. The difference is the Rondec is just a metal bullnose 1/4 round, while the Step Rondec has a 1 1/4" metal skirt that comes down off the bottom of it. First pic is the Rondec. Second is the Step rondec:
"Whether you think you can, or you think you can't, You're probably right."
http://www.creativeceramicandmarble.com
Bill_Vincent is offline   Reply With Quote
Old 08-22-2008, 01:27 AM   #7
Fixer-'til-broker
Rewards Points: 262
That second pic looks just like my tile and what I want to do with it, but have more tile on the vertical edge and then carpet continuing on the floor into the next room. I was looking for a radius edge tile that would match or accent, but haven't been so lucky yet. I might be able to bullnose this tile (?) and then grout to hide/match. I wanted to make a short ramp, but I'd have to modify or replace the carpet.
Everything would be easier if I could figure out what I want ahead of time...but then the wife has her say...ugh!
Old 09-02-2008, 05:40 PM   #8
Fixer-'til-broker
Rewards Points: 262
UPDATE:
I went ahead with my original plan. I cut the vertical tiles about 3/8" thinner and then smoothed the edges on top with a grinder and a 60-grit flap wheel.
Now my only problem is that the new tile looks so much whiter than the tile that was already down, even though it came from the same batch.
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile roof questions/repairs help please xoroniox Roofing/Siding 3 12-17-2006 02:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
