Tile Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 11:26 PM   #1
Rewards Points: 12
Tile repair
I have a broken tile in my shower leaving about a 4x2 inch hole. Rather than replacing the tile i would just like to fill in the hole with grout. Do i need anything beside the grout like a grout sealer?
jseymour186 is offline   Reply With Quote
Old 09-03-2011, 05:40 AM   #2
m1951mm's Avatar
Grout is not designed to fill a void that large. When mixed to the right consistency it would "roll" out of that large of a void due to gravity. I dont feel you will get a good water tight fix by trying to do grout alone. A tile retailer, be it a home improvement center or a tile dealer, will cut a piece of tile for you (make sure to leave about 1/16" to 1/8" gap, that is where the grout will seal the opening). It may not match what you have now, but atleast you will have a much more permement water tight fix.
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
The Following User Says Thank You to m1951mm For This Useful Post:
oh'mike (09-03-2011)
Old 09-03-2011, 08:53 AM   #3
A Little Of Everything
Rewards Points: 1,364
You're much better off carefully chipping out the remainder of the broken tile, and replacing it, even if the replacement tile is not identical.
DrHicks is offline   Reply With Quote
Old 09-03-2011, 10:45 AM   #4
Rewards Points: 12
What tool would you recommend for chipping out the remainder of the tile?
Old 09-03-2011, 11:32 AM   #5
m1951mm's Avatar
With a soft hand you could try a hammer and flat blade screwdriver. What you do not want to do is harm the backing where the tile is attached. Wear protective glasses,!!!!!!!!!!!!!!! ceramic in the eyes is not fun, I know, and tap tap tap till the piece you want to come out is gone. Get the new piece, grout and shower to your hearts contents safely!!!!!!!
Mickey
Old 09-03-2011, 10:07 PM   #6
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,086
Before you start trying to remove the tile, remove the grout from all the way around it. They make a grout saw for this, or just use an old screwdriver and dig it out. Removing the grout will lessen the chance of damaging the surrounding tile.
The Following User Says Thank You to Blondesense For This Useful Post:
m1951mm (09-04-2011)
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
replacing tile on durock, how to repair part of durock board already on floor? gared@roadrunne Tiling, ceramics, marble 1 01-15-2011 05:01 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 03:31 PM
How Do I Repair an Improperly Installed Shower Floor MartinGale Flooring 3 11-26-2007 08:36 PM
