Tile Removal With Heat - Flooring - DIY Chatroom Home Improvement Forum
Old 08-10-2011, 08:18 PM   #1
Rewards Points: 370
tile removal with heat
has anyone tried removing asphalt tiles (asbestos containing usually) with an IR heat system?
I found 2 here...
http://www.uasautomation.com/
http://www.novatekco.com/html/NovaStrip.html
the US automation has one for under 800 to buy that does single tiles while the novatekco is well over 1k for a similar product but I was wondering if anyone has come across any others, perhaps one that does paint removal and tile removal?
any experience is greatly appreciated.
Thank you
MLMIB is offline   Reply With Quote
Old 08-10-2011, 09:51 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Look for a used propane machine.
XXX
Old 08-11-2011, 08:02 AM   #3
Rewards Points: 370
I googled and it came up with propane strippers which seem to be more on the cleaning tile rather then heating them up so the mastic gets loose.
Did I find the wrong product? Is there something else I should be finding?
Old 08-11-2011, 08:12 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Tile removal and asbestos abatement contractors have been using propane heaters to remove vinyl tile for a long long time. Have no idea what they call the machines but the heat removal concept is not new. I thought maybe a person could find a used machine cheap compared to some IR fancy shmancy machine. Just a guess.
XXX
Old 08-11-2011, 08:22 AM   #5
Rewards Points: 370
Oooo, yea, I was considering just getting one of those weed burning devices and having a friend heat the tiles up as I work them but was hoping there was a similar but not as wild approach. Maybe someone else will have a product name I can hunt down.
Thanks for the help
Old 08-11-2011, 08:30 AM   #6
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How much tile are you removing?
XXX
Old 08-11-2011, 08:37 AM   #7
Rewards Points: 370
A little over 1000 sq ft, maybe 1,200 total. Might not do it ALL in one effort but it'll all get done
Old 08-11-2011, 04:48 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I guess you know there are also electric walk-behind floor scalers as well as pneumatic scalers. Both can be rented for a small fee.
XXX
Old 08-11-2011, 09:40 PM   #9
Rewards Points: 370
both of those seem to be the types that just pop them up, which is nice but if the mastic is real good it might break the tile into a few pieces and since I'm worried about asbestos I'm trying like the devil to avoid that, unless I'm finding the wrong products.
Old 08-12-2011, 06:45 AM   #10
Mold!! Let's kill it!
Rewards Points: 2,012
The machine will cost more than an abatement contractor. For a DIY project with no deadline, I'd go with a small propane torch. Wear a real respirator, no paper dust masks. Damp wipe everything as you go and don't let tile dust travel everywhere in the house.
Help with Heat Pump System Wiring AlanScott HVAC 11 10-10-2010 12:19 PM
uneven heat: testing ceiling radiant heat /finding cables/fix cables martinradiant Electrical 1 10-03-2010 08:22 PM
subfloor for radiant heat with tile Jan54 Flooring 1 06-22-2010 02:44 PM
Newbie to 1950's house - tile adhesive removal? FixyChik General DIY Discussions 20 01-08-2009 09:34 AM
removing tile over radiant floor heat bayerja Flooring 3 07-15-2008 06:52 AM
