Tile Problem - Flooring - DIY Chatroom Home Improvement Forum
Old 09-25-2008, 12:14 AM   #1
Question
Tile Problem
I have tiles layed across a joint between a heated cement floor and the concrete footing. (Timber Frame house) We have experienced grout cracking and in places a couple of tiles. We used an anti fracture membrane originally, obviously this has not worked. Is there a flexible grout compound that would solve this problem while still being able to match the sanded green grout on the rest of the floor.
Any help on this would be appreciated
jdunc is offline   Reply With Quote
Old 09-25-2008, 07:28 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is one side of the crack higher than the other side?
Old 09-25-2008, 08:42 PM   #3
The crack on the outside tile is higher than the inside tile and I believe that is where the movement is. The antifracture membrane might be mitigating any side to side movement but the up and down movement is what appears to crack the grout. This is just a quess from observation over the 12 years. I have re grouted twice and it is in need of it again.
Old 09-25-2008, 08:46 PM   #4
Registered User
Termite's Avatar
Although it would be a band-aid fix, you can buy sanded caulk in a lot of different shades and colors to pretty closely match most grouts. Most tile suppliers carry a lot of colors, and box stores carry a few colors.
Old 09-25-2008, 09:46 PM   #5
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Anti-fracture membranes are not intended to protect agaist the issue you are experiencing, in fact they all disclaim any protection benefits against vertical movements. I gaurantee you the anti-fracture membrane HAS NOT failed.
Without getting to the bottom of the problem the only thing you can do is use a flexible caulk to fill an unsightly crack. Be careful tho 'cause those crack edges are probably razor-sharp.
Old 09-26-2008, 09:09 AM   #6
It souds like caulking of some sort will outlast grout. I will try to track down something that will match the rest of the grout. Thanks for your help. Jd
Old 09-27-2008, 09:31 AM   #7
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The are colored caulks available to match every color of grout there is.
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Tile Gap problem trueform General DIY Discussions 5 07-12-2008 04:31 PM
Newcomer needs help with tile problem Eike General DIY Discussions 3 03-18-2008 09:04 AM
Tile Floor Problem overwhelmed Flooring 7 02-20-2008 05:42 PM
Problem Glass Tile Shower robin2107 Remodeling 9 04-23-2007 08:19 PM
