Old 01-04-2007, 11:17 PM   #1
tile/plywood removal
House I purchased and 1/2 laminate 1/2 ceamic tile on main floor. I am removing ceramic and after removing initial tiles notice that there is 1/4 inch plywood over origional linolium. I want to remove plywood but cannot remove morter to expose screws. Any suggestions?
civilstew is offline   Reply With Quote
Old 01-17-2007, 10:02 PM   #2
Handyguy
Brik's Avatar
Send a message via Skype™ to Brik
Brute force
maybe take circular saw, set to 1/4" depth (so it just starts to cut the original
Linoleum), use a junk blade and score the plywood then pry it up. Crowbar the screws or use vice grips to turn them out one by one after you tore up the ply from around them.
Then remove the linoleum. begin anew.
Brik is offline   Reply With Quote
chimney stack removal davedish Building & Construction 9 02-22-2007 09:07 PM
Plaster removal decision Sarai Remodeling 2 09-08-2006 04:15 PM
need opinion on paint removal tonail1 Painting 1 07-03-2006 07:34 PM
Drywall or Wallpaper removal? Slicendice Remodeling 3 03-16-2005 06:41 PM
