Tile Over Vinyl Floor?? - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-01-2011, 09:16 PM   #16
DIY staff
Rewards Points: 7,174
Originally Posted by ttr13r View Post
Bud...LMAO!!!! i don't KNOW know how to start a new topic... Rusty was right! Plus, I was in a hurry this morning!!
To start a new thread---go to 'forum'
select the appropriate topic--"flooring' for instance
at the top of the column will be a box marked 'start a new thread'
click on that----Mike---
ttr13r (08-02-2011)
Old 08-01-2011, 09:37 PM   #17
Tileguy
JazMan's Avatar
Rewards Points: 198
pwgsx,
The top vinyl peels off, under it is almost like carboard- no foam.
How can you be so sure? There is a 100% chance there is foam.
Layer 1 is the backing. In the old days, (mid-80' + - and prior), it usually contained asbestos. Layer 2 is the foam. With cheap thin vinyl the foam is likely to be only 1/32". The top wear layer is pvc, like a sheet of Saran Wrap.
The foam is treated with a chemical where the pattern and texture will be that prevents it from 'rising' when it's baked. So that is how you get the pattern and texture. After that the pvc finish is applied, finished.
I know who you are. You are one of those guys who thinks you can reinvent the wheel to make it better. I say that cuz you wanna add #333 additive to Versabond. Why would you do that? You are not the first to have this situation. It's been done millions of times.
So, peel the top layer including the foam. Soak the remainder with hot water and scrape with a wallpaper scraper. http://www.core-industrial.com/manag...%20(Small).jpg
Jaz
Old 08-02-2011, 12:56 PM   #18
Rewards Points: 254
Jaz
I only said Versa Bond bc thats what this tile guy said at Home Depot when I called. However I looked at it and its Modified. I do know the 333 needs only to be added to Un-Modified Motar and will be getting that shortly. Everyone can rest easy
pwgsx is offline   Reply With Quote
Old 08-02-2011, 08:17 PM   #19
Tileguy
JazMan's Avatar
Rewards Points: 198
You have not yet learned the #1 rule in flooring DIY. Do NOT ask for or listen to advise given by those nice people who wear vests. There are a few exceptions to this rule, very few. The higher ups at those companies would rather not hire anyone with experience. Yours is a simple thing, others have not been as lucky.
Jaz
Old 08-02-2011, 08:21 PM   #20
Learning by Doing
Leah Frances's Avatar
Good for you for sticking around and reading everything....
Truth is they/we won't rest easy until we know a project is going to get done right the first time. It's cause we've all learned the hard way....
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 08-02-2011, 08:25 PM   #21
Tileguy
Bud Cline's Avatar
Rewards Points: 558
There are no tileguys at Home depot.
XXX
Old 08-03-2011, 01:06 PM   #22
Rewards Points: 254
Thats not what this guy seems to think, but I somehow knew better.
On that note, other than Lacicrete brand, what is another worth while non mod. thin set??
Old 08-03-2011, 05:02 PM   #23
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Kerabond.
XXX
Old 08-03-2011, 05:07 PM   #24
Tileguy
Bud Cline's Avatar
Rewards Points: 558
ttr13r: "Bud...LMAO!!!! i don't KNOW know how to start a new topic... Rusty was right! Plus, I was in a hurry this morning!!"
Oh great Teri, just my luck! I try to give you a little credit and put a positive spin on things and you fess up in front of everyone. Didn't your mother ever tell you that raw-honesty is a great virtue but also a virtue you can trip over? You would never make a good politician.
XXX
Old 08-04-2011, 12:13 PM   #25
Bud...In front of everyone.. chivalry is not dead!! Thank you for having my back! I'm just one of those people who are too honest, at the expense of myself (and others?) What can I say, I'm a New Yorker!!! I'd make a horrible politician!!
ttr13r is offline   Reply With Quote
Old 08-04-2011, 04:12 PM   #26
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I'm a New Yorker!!!
And yet still smart enoufgh to move to Oceanside.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
ttr13r (08-06-2011)
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 10:07 PM
Can I lay ceramic tile on a pier and beam with Vinyl? sandy 74 Tiling, ceramics, marble 1 02-17-2011 10:51 PM
Tile, Radiant Floor, Avoiding screwing into the water lines Cecosugi Flooring 10 01-28-2010 08:00 PM
Peel and Stick Tile Over Existing Bathroom Ceramic Tile Floor mark2741 Flooring 2 11-03-2009 07:08 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 11:58 AM
