Old 01-14-2007, 03:42 PM   #1
Tile over, or tile under?
I'm planning on replacing the lineoleum in my kitchen with tile or natural stone. The existing linoleum is atop luan, and the luan extends beneath the kitchen cabinets. I see two possible approaches:
1) Only remove the luan where its currently exposed, put down hardibacker, and install tile. The problem here is making clean cuts at the cabinet edges, and the tile will effectively "lock in" things like the dishwasher and range.
2) Remove the cabinets, pull up ALL of the luan, lay down tile everywhere, and reinstall the cabinets on top of the tile. The only problem there that I see is added expense and added work.
I assume option #2 is is the proper approach? Any suggestions when it comes to putting cabinets on top of tile?
~ Will
jeffyisfive is offline   Reply With Quote
Old 01-15-2007, 04:40 PM   #2
renovations
Option 3- Pull the range and d/w, remove all exposed luan, put down cbu, tile, seal, replace range and d/w. Make sure you're not going to have height issues with the d/w fitting under the counter.
Bonus is offline   Reply With Quote
Old 01-15-2007, 10:07 PM   #3
remodeling pro
Agreed, this is the way to go. Do not even entertain the idea of locking appliances in position with the new floor. The range, either slide in or free standing should pose no problem. And unless the dw is a newer tall tub or totally sound enclosed case model, it should also have enough adjustment to fit. Slide the dw out, lower the leveling feet to their mininum and check the height to be sure.
troubleseeker is offline   Reply With Quote
Old 01-16-2007, 09:49 PM   #4
Make sure the linoleum doesn't have asbestos in it before doing anything.
Krichton is offline   Reply With Quote
Old 01-24-2007, 12:29 PM   #5
Thanks for the input, guys!
Tile over Tile ?? Piney Flooring 17 02-06-2012 10:59 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 08:15 AM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 03:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 03:14 PM
