Old 11-22-2012, 01:09 AM   #1
Tile over Tile over Radiant Heat
I just bought a home on a slab with radiant hot water heat. The floor is all tiled on one level - about 22 years old and showing age. Can I tile over the tile and what would be the effect on the radiant heat system efficiency? Our climate is pretty cold in winter.
Thanks.
ChloeHobbes is offline   Reply With Quote
Old 11-22-2012, 06:15 AM   #2
Super Moderator
Tile over tile can be done with a bit of prep and the correct modified thinset---
I doubt that the extra layer of tile will affect the heating noticably---you are adding thermal mass---
Is the existing tile set correctly? No loose or hollow tiles?
Old 11-22-2012, 10:52 AM   #3
The tiles all seem to be set correctly - there are chips around the edges, one "gouge" about 1 inch around, and a few cracks that are not lifting.
The tile store quoted $2/square foot to demolish, and at 1700 square feet of tile, I don't know if it's worth it. BUT, If we tile over tile, we still have to adjust doors, remove and adjust outdoor french and sliding doors to adjust height, raise 2 toilets (?), and whatever else needs adjusting. The cost of adjustments may make demolition seem cheap...???
Old 11-22-2012, 11:27 AM   #4
Super Moderator
That's not an unfair price---you will have a better install---if it's in the bank and you can spare it---I would recommend removing the old tile---
However---a safe install can be done over the top of good sound existing tile-----
Old 11-22-2012, 11:32 AM   #5
Thanks.
And thanks for your replies on T-Day.
The Following User Says Thank You to ChloeHobbes For This Useful Post:
oh'mike (11-22-2012)
Tags
radiant heat, tile, tile over tile
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
Need Help with Radiant + AHU Heat Coil Control Wiring Tommathome HVAC 0 04-03-2011 03:30 PM
subfloor for radiant heat with tile Jan54 Flooring 1 06-22-2010 03:44 PM
Radiant floor heat question. ingeborgdot Remodeling 6 03-23-2010 01:05 PM
Radiant Heat and Tile Texasguy HVAC 5 04-07-2009 11:14 AM
