-   -   Tile over Tile over Radiant Heat (http://www.diychatroom.com/f5/tile-over-tile-over-radiant-heat-164351/)
ChloeHobbes 11-22-2012 01:09 AM
I just bought a home on a slab with radiant hot water heat. The floor is all tiled on one level - about 22 years old and showing age. Can I tile over the tile and what would be the effect on the radiant heat system efficiency? Our climate is pretty cold in winter.
Thanks.
oh'mike 11-22-2012 06:15 AM
Tile over tile can be done with a bit of prep and the correct modified thinset---
I doubt that the extra layer of tile will affect the heating noticably---you are adding thermal mass---
Is the existing tile set correctly? No loose or hollow tiles?
ChloeHobbes 11-22-2012 10:52 AM
The tiles all seem to be set correctly - there are chips around the edges, one "gouge" about 1 inch around, and a few cracks that are not lifting.
The tile store quoted $2/square foot to demolish, and at 1700 square feet of tile, I don't know if it's worth it. BUT, If we tile over tile, we still have to adjust doors, remove and adjust outdoor french and sliding doors to adjust height, raise 2 toilets (?), and whatever else needs adjusting. The cost of adjustments may make demolition seem cheap...???
oh'mike 11-22-2012 11:27 AM
That's not an unfair price---you will have a better install---if it's in the bank and you can spare it---I would recommend removing the old tile---
However---a safe install can be done over the top of good sound existing tile-----
ChloeHobbes 11-22-2012 11:32 AM
Thanks.
And thanks for your replies on T-Day.
