Tile Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 04-14-2010, 11:56 AM   #1
Tile over tile
I have an old floor and was thinking about tiling over it. The current tiles are awful but the floor is solid. Would I have to scuff it up a bit first before the thinset?
Is there a flange extension for the toilet?
Would that be ok?
Pros's ... Cons?
coopns is offline   Reply With Quote
Old 04-15-2010, 06:13 AM   #2
It can be done, and I have done it, but don't like the idea. I use it as a last resort. The old floor must be clean and needs to roughed up to give tooth for the new thinset. And there are spacers available for toilet flange.
I have a roto hammer that will make quick work of just the tile layer in an average bathroom, several hours worth of work. Assuming the underlayment is sound, it is ready for new tile.
Old 04-15-2010, 08:38 AM   #3
If I decide to pull up the tile, what about the thinset? Is that a horror show to clean up? What tools would you use or could I drop the durock right over the thinset?
Thanks.
Old 04-15-2010, 12:55 PM   #4
I've never done tile over tile but my current home had three, that's right, 3 layers of tile in the foyer and kitchen. It can be done but it's always better to do it right.
I was able to remove all 3 layers for about 400 sqft in one weekend. the worst part was the floated concrete over the plank subfloor. The tile layers came up quite easy using a prybar and hammer and one of the scraper tools they use to pry up roof shingles.
BTW, the thinset usually comes up with the tile fairly easy. You may get some junks that stay stuck to the subfloor but the roof scraper should make short work of that.
anonymouscuban is offline   Reply With Quote
Tile over Tile ?? Piney Flooring 17 02-06-2012 09:59 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
Trimming installed tile with tile blade in normal circular saw? jdraughn Tools 5 12-13-2009 09:07 PM
Some questions about laying Tile? DiY_RooK Flooring 1 08-31-2007 09:35 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 02:14 PM
