Old 10-13-2006, 12:08 PM   #1
Default Tile over Tile ??
Greetings--
Small bathroom remodel (4x6ft floor only).
Original tile is set over concrete floor. After several wacks with a hammer and chiisel, we determined moving it is going to be a huge pain !!
Sooooooo-- How does one go about installing new tile over old tile ?
One tile store said they would put down a layer of material (thinset of some sort) to level the existing tile, filling in the existing grout lines. Then lay thinset and new tile over this new surface.
Another store said they clean the existing tile, rough it with a sander, then just lay the new tile right over the old tile, with a slightly thicker layer of thinset (actually he used another term for a different setting material).
Comments ??
Piney is offline   Reply With Quote
Old 10-13-2006, 12:32 PM   #2
DIY'er
Both suggestions are options...
First of all, you need to determine if it truly is a "concrete floor" the tile is set on...Is you house on a slab? If not then the floor you describe would be most likely a mortar bed, which may or may not be in good enough condition to tile over.
Second, although it is better not to tile over tile you can as long as you use good materials. Buy a GOOD modified thinset and either:
1. sand the surface of the old tile and lay the tile being sure to really "burn in" the thinset before you lay it with the flat side of thetrowel...in other words, make sure you get the thinset really well adhered onto the old tile, then "comb" a layer in with the notched side of the trowel. and then be sure to "backbutter" the tile before you set it....
2. "Skim coat" the original tile with thinset, let it cure, and then thinset and tile over that after...the point is to level off the surface for the tile...
I have done a couple tile over tile jobs...one in my house and one in my dads house...I just sanded the surface well and then just layed the tile...ALthough, If your floor is bumpy and has minor dips you can fill them with a skim coat.
BY THE WAY....NEVER USE SO CALLED PRE-MIXED THINSET OR MASTIC TO SET FLOOR TILE. No matter what a home shmeepo worker says.
Hope that helps....
Doug Russell
"What if the hokey pokey really IS what its all about."
dougrus is offline   Reply With Quote
Old 10-13-2006, 02:39 PM   #3
They're all fixer-uppers
J187's Avatar
Piney, I very recently tiled over the old tile in bathroom. Two things to definitley consider
1. is the existing tile in good shape, are in any tiles loose?
2. how will the new height effect the room, ie you will probably need to extend the closet flange for the toilet, maybe cut the bottom of doors, raise vanities, and account for a new height difference at the transition point between the room and the hall.
I recently tiled over my old tile which was in perfect condition. I hope you didn't do any damage when you first tried to remove the old. I used a nice modified thinset and simply cleaned and scuffed the old tiles, applied my thinset like usual and tiled. I strongly recomend you get your tiles and thinset from a tile store rather than a big box home improvement store. The stronger tiles and better thinset will greatly aid your project.
TRY IT, IT'S SO MUCH FUN!
J187 is offline   Reply With Quote
Old 10-13-2006, 02:45 PM   #4
If you did decide to take another crack at removing the old tile, I have heard (although not personally tried) that those air chisles that you can buy for under $20 work very well for this. This does require to you to have, or be able to borrow, an air compressor. Try to chisel underneath a tile and pop it up. Getting it started so you can do this will probably be the hardest part.
LanterDan is offline   Reply With Quote
Old 10-13-2006, 02:48 PM   #5
J187's Avatar
If its a mortar bed, you'd have to be willing to do some work to that after removing the tiles, chances are pretty good something will need to be done. You may have better luck just going right over the old. If the old tiles are solid, its perfectly fine.
Old 10-13-2006, 02:50 PM   #6
DIY'er
Agreed on all points....
Changing all the heights can be a pain. Toilet flange you can get a flange extender but for thresholds and door casings, you have to do some cutting and/or removing.
Make sure you email back and let us know what is really under the floor and what condition the tiles are now in...As J187 said, tiling over a solid, non-moving floor is essential.
HD does have crappy tiles so go to a tile store as J187 said...
Although if you do need to buy modified thinset from there for whatever reason, the Versabond is a very good modified thinset.
Doug Russell
Old 10-13-2006, 02:55 PM   #7
DIY'er
If it IS a mortar bed it would be somewhat difficult to get that tile up without cracking or damaging the bed and then, likely you will be looking at some serious demo to get that floor up...Ive done it a few times and it is no picnic.
Doug Russell
Old 10-13-2006, 04:57 PM   #8
Greetings--
Thanks for all the advise--
== The original tile IS on concrete slab flooring, as is the rest of the house.
== The original is definitely STUCK well-- none loose and quite difficult to chip loose. I tried this on a tile that would go under a new vanity-- no way its coming up with even moderate force.
Regarding problems with the additional height-- I can add an extension to the toilet flange. We're replacing the vanity anyway so that's not an issue.
Old 10-20-2006, 11:41 PM   #9
Carpenter
DecksEtc's Avatar
An air chisel works well for this type of problem. It's a slow process but it does work.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 10-22-2006, 12:03 PM   #10
Getting under the 1st tile is the hardest part. After that, if you get under the tiles and theyll all pop up....once we got to that point, we realized taht if we went down to the bottom, an entire portion would pop up all at once.
Lucky for us, we had this at our disposle.
dre2142 is offline   Reply With Quote
Old 12-10-2006, 09:27 PM   #11
Default Update
Greetings--
I"ve been able to get most all of the vinyl adhesive off via scraping and paint thinner and elbow grease (and a little )
Folks have said to sand the tile so that the new adhesive/mastic will stick to it under the new tile.
QUESTION-- About sanding. I took my belt sander and put on a #80 belt rated for tile/cement. It dulled the surface some, but not a lot IMO.
How much of a rough surface is needed ?
Should I use a grinder or something similar ?
QUESTION-- About cleaning. I used paint thinner to dissolve the glue. How clean does the tile surface need to be.
Should I go over the surface with some other cleaner ?
THanks !!
More On This Topic
Hi, I’m Faith and I’m here at Flat Fork Studio and I’m here to show you some basic tools that you want to have on hand when preparing to do your mosaic tile project. First we have a caulk gun, Liquid Nails adhesive. This is one type of... Read More »
Hi, I’m Faith, I’m here at Flat Fork Studio and I’m going to show you how to glue your mosaic pieces down to your final piece. And at this point I would use a thinset- a premixed thinset- and it comes from the hardware store already... Read More »
I’m Lee. I have a degree in architecture and about ten years experience in the construction field. And we have about finished the kitchen remodel. All we have left to do is the counter tops and decide on something on the floor. The first thing that... Read More »
Hi, I’m Faith and I’m with Flat Fork Studio, and I’m here to discuss the different kinds of adhesives that you might want to use in doing your tile mosaic project. There’s several different applications. You first need to decide... Read More »
Hi, I’m Faith and I’m here at Flat Fork Studio, and I’m going to show you how to cut a tile using a handheld tile cutter. Basically, what you do is you lay your tile out- say if I want to cut this tile in half- I’ll lay my tile... Read More »
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 05:31 PM
Subway tile installation bigboyjoel Flooring 3 08-02-2007 09:15 AM
HELP! Tile flooring question Marsy Flooring 1 02-16-2007 11:22 PM
Tile roof questions/repairs help please xoroniox Roofing 3 12-17-2006 04:02 PM
Tile and laminate, or get rid of tile? kfoster Flooring 10 03-17-2006 04:14 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
