Tile Over Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 10:43 AM   #1
tile over tile
we have existing 16" x 16" concrete tiles in kitchen/dining area n we r going to re-tile with 12" x 12" concrete tiles... can we tile over the existing tiles and if so what preparations do we need to do? or can we just mortar directly on top then lay new tiles?
lawson4803 is offline   Reply With Quote
Old 06-07-2011, 01:12 PM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 1,074
Concrete tiles? Do you mean ceramic?
I'm no expert so I'm not gonna touch the idea of if or how to do this. I will tell you to take a good look at the area before you even consider this. Will the difference in height create any trip hazards? Do you have a dishwasher? Adding a layer of tile in front of it may make it difficult if not impossible to pull it out if necessary. What about doors? If you have an exterior door that swings inward will there be enough clearance to open the door? While I have read that it is possible to tile over tile in some cases, it isn't necessarily the best way to go.
Edited to add: Also consider the condition of the current tile. Loose or cracked tile or grout usually means an underlying problem. Covering it won't work.
The Following User Says Thank You to Blondesense For This Useful Post:
lawson4803 (06-09-2011)
Subfloor and Porcelain tile prep sugarhousemama Flooring 4 12-03-2010 07:47 PM
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 11:00 AM
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
