Old 02-13-2012, 11:45 AM   #1
Tile over slate
I have a 270 sq. ft. kitchen that I'm flooring with 20x20 porcelain tile. Under the vinyl that's currently there, I found slate that was installed back in the late 70's. It all appears in solid condition, no cracks, or movement, from what I've seen.
Can I just tile over it, would using ditra help, or should I remove it entirely (I would really like to avoid this)? Any other suggestion would be great.
Thanks!
Fa'iz is offline   Reply With Quote
Old 02-13-2012, 12:11 PM   #2
Tile over slate
Far better to just remove the old slate.
It's going to throw off your floor heights, if you have a dishwasher it may not fit under the countertop.
Why take a chance on that new floor cracking?
Old 02-13-2012, 12:30 PM   #3
Tile over slate
I'm really new to DIY work, since this is my first home. What's the best way to go about removing the slate?
Old 02-13-2012, 01:01 PM   #4
Tile over slate
I use one of these tools with a tile chisle. It's a 2" wide chisle in it with a raised spot in the middle of it so it lifts and cracks the tile. Make sure to wear safety glasses.
You could even rent one at Home Depot. They rent the Hilti brand but works just as good.
Get yourself some 5 gal. buckets to haul it out of the house.
remove slate tile enhancer? denemante Flooring 1 12-23-2011 03:37 PM
Travertine Tile Help MikeinTexas Flooring 1 09-07-2011 11:43 AM
slate tile outside over concrete critterlover Flooring 3 08-12-2011 10:36 AM
Slate tile in a shower minellm1 Remodeling 4 04-17-2011 09:31 PM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 08:48 PM
