Tile Over Sheet Vinyl? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 09:13 PM   #1
Tile over sheet vinyl?
I am going to tile a bathroom floor. It now has sheet vinyl with 3/4" plywood under that. Is it necessary to remove the sheet vinyl? My only concern is that there will be glue left behind for sure. Its not attached to the floor very well right now.
Second, I like to use Hardee Board. Is 1/4" ok for the floor? 3/4" plywood is below it.
Also, I've heard that you're supposed to use thinset under the hardee board? Should the thinset be modified or non-modified? They said only Holmes on Homes which one to use but it was too quick and couldn't write it down. I know modified is used for the walls, but does it go between plywood and hardee board too?
jonathan03 is offline   Reply With Quote
Old 07-06-2010, 05:36 AM   #2
DIY staff
Rewards Points: 7,174
You will definitely want to remove the old floor covering. Add screws to the old 3/4 subfloor if there is any movement or squeaks.
It doesn't matter which thinset is used under your backer---modified or un modified will work fine.
If the room is small,I suggest you get a bag of modified--it may be large enough to set the backer and the tile.
---Mike---
Back Splash Tile Over Old Sheet Rock? Stcrosby Remodeling 3 01-03-2010 12:46 PM
Should I use tile or vinyl Quadfam4 Tiling, ceramics, marble 3 04-30-2009 10:58 AM
Vinyl tile trouble juju647 Flooring 15 08-31-2008 11:06 AM
Sheet vinyl seam separating tmpyankee Flooring 11 08-30-2008 08:28 PM
Vinyl tile over luan? irishghandi Flooring 1 03-08-2006 02:46 PM
