Tile Over Plywood Repair - Flooring - DIY Chatroom Home Improvement Forum
Old 09-04-2009, 09:33 PM   #1
tile over plywood repair
i had to replace a 3x5' plywood area outside my shower along with shower floor.....I used one big sheet of plywood...... After laying the 1/4" cement board back down. The tile is flush with existing tile. After mortar i think it will be a hair to high. Can i remove that cement board and maybe do something else on the floor outside the shower?
Can get picutres if needed......
Ineedhelp2009 is offline   Reply With Quote
Old 09-05-2009, 04:48 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
How was it done before? What is the cause of the variance?
XXX
Old 09-05-2009, 05:24 PM   #3
Well I should have put that in there!!!Will be a little more specific it's not the whole area just a few small spots.
BEFORE plywood, 1/4" cement board, mortar, tile
Cause-debris maybe on the truss beneath, keeping me 1/8" high
I was considering just removing that particular piece of cement board (less than a sq foot) and doing just a mortar base and hope it sticks.... the two high spots are against the wall, non-traffic areas??? what would you do?
Old 09-06-2009, 11:47 AM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Can you grind the backeboard down? You only need a reduction of about 1/16" or so. Use a corborundum rub stone or even an orbital sander with 50-60-80 grit paper.
XXX
Old 09-06-2009, 04:38 PM   #5
thought about the sanding, but no belt sander or orbital sander
Thanks again bud will try that stone first!
Tile over plywood? Thurman Flooring 3 07-12-2009 10:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 08:06 PM
Tile Plywood Sub-Floor Help woodlab Flooring 1 10-21-2008 11:58 PM
Tile or Plywood under cabinets nicksr Remodeling 5 12-02-2007 06:20 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
