-   -   tile over plywood repair (http://www.diychatroom.com/f5/tile-over-plywood-repair-52331/)
Ineedhelp2009 09-04-2009 08:33 PM
i had to replace a 3x5' plywood area outside my shower along with shower floor.....I used one big sheet of plywood...... After laying the 1/4" cement board back down. The tile is flush with existing tile. After mortar i think it will be a hair to high. Can i remove that cement board and maybe do something else on the floor outside the shower?
Can get picutres if needed......
Bud Cline 09-05-2009 03:48 PM
How was it done before? What is the cause of the variance?:)
Ineedhelp2009 09-05-2009 04:24 PM
Well I should have put that in there!!!Will be a little more specific it's not the whole area just a few small spots.
BEFORE plywood, 1/4" cement board, mortar, tile
Cause-debris maybe on the truss beneath, keeping me 1/8" high
I was considering just removing that particular piece of cement board (less than a sq foot) and doing just a mortar base and hope it sticks.... the two high spots are against the wall, non-traffic areas??? what would you do?
Bud Cline 09-06-2009 10:47 AM
Can you grind the backeboard down? You only need a reduction of about 1/16" or so. Use a corborundum rub stone or even an orbital sander with 50-60-80 grit paper.:)
Ineedhelp2009 09-06-2009 03:38 PM
thought about the sanding, but no belt sander or orbital sander :laughing:
Thanks again bud will try that stone first!
