Old 03-10-2013, 11:58 PM   #1
tile over plywood over asbestos over concrete??
I have a concrete floor (above grade over garage) with some type of sheet flooring glued to it. It was put down in the late 1940's.
Can I screw down plywood or cement board to seal in the old floor and give me a new substrate for tile?
Thanks DIYérs
brian sansone is offline   Reply With Quote
Old 03-11-2013, 06:19 AM   #2
Super Moderator
Bad plan---Ply over a concrete floor--even above grade---often puckers and swells,causing tile failure--
If the old sheet goods can not be removed easily--you could encapsulate it under a layer of self leveling compound-----then set the tile on top of that----
Old 03-11-2013, 09:00 PM   #3
what about attaching cement board instead of plywood?
The sheet flooring is thick and spongy. I'm worried that it would not
be structurally sound enough for thinset and tile.
Old 03-11-2013, 09:15 PM   #4
Super Moderator
You are going to have to remove that old floor covering----you can not attach cement backer over the concrete---
Sorry---is there a reason you don't want to remove it?
Old 03-11-2013, 09:24 PM   #5
Tileguy
JazMan's Avatar
The next person that wants to install plywood (or a concrete backer) over concrete is gonna make me scream!!
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 03-11-2013, 10:43 PM   #6
The old flooring is asbestos.
I install into concrete all the time. I could easily screw down cement board onto the concrete. Several concrete companies have told us encapsulation is not an option. They believe the bed and tiles will crack because of the spongy flooring. Asbestos removal here will cost far more than we have in our budget. Will screwing cement board down not work either?
We are running out of options here.
Concrete floor over tile Cellomangler Flooring 13 08-25-2012 07:45 PM
Concrete prep for outdoor tile onthejob Concrete, Stone & Masonry 8 03-29-2012 01:34 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 02:46 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Ceramic tile over asbestos tile question MLMIB Tiling, ceramics, marble 4 01-10-2011 08:58 PM
