Tile Over Plywood? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-11-2009, 03:02 PM   #1
Household Handyman
Rewards Points: 1,408
Tile over plywood?
Lets (apostrophe still not working) try to make this short and sweet. Friends water heater leaks from the top, ruined 80 sq. ft. of parquet over particle board flooring. I found under the particle board, roofing felt then plywood which look good. So we go back with plywood and now homeowner wants to lay tile he bought at the orange big box store where the "tile associate expert of the day" sold him the tile, and the mastic to put the tile on top of the plywood. WHOA NOW! Im no tile man but Im not sure tile goes over plywood. Does tile not go over some type of special underlayment which goes on top of the plywood? Thanks, David
Old 07-11-2009, 03:10 PM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 110
I'm no tile man either, but mastic on the floor is a no no, too.
Old 07-12-2009, 07:10 AM   #3
Anything with water in it should not go directly on plywood, there should be a backer board for tile. And floors less than 1 1/4" are not rigid enough for tile.
Old 07-12-2009, 09:05 AM   #4
ccarlisle's Avatar
or Ditra...
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Tile Plywood Sub-Floor Help woodlab Flooring 1 10-21-2008 10:58 PM
Tile or Plywood under cabinets nicksr Remodeling 5 12-02-2007 05:20 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 08:48 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
